Lepai T-Amp with TA2020 - Page 100 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 4th December 2011, 06:57 AM   #991
Hi Everyone !
Got mine 2 days ago, it is one of the latest versions. Changed all electrolytics with panasonic FC. Bypassed the pre stage with 2 thetta MKP 2.2uf & added 2 extra rca input plugs, but kept the pre stage for any future needs (if you wanna connect a cd player). Used a 6.3A /18v power supply with a step down dc to dc converter adjusted at the exact 12v. It is an smd board but components are easy to extract. Pin No 18 is still connected to a kind of stupid protection circuit (looks like a resistor with a transistor) but i just cut the trace and left it open. By the way the 3300uf/16v electrolytic at the power supply stage was a used one & leaking (what a Chinese quality check ?) so you better change that and remove the inductor or sort it.
First audition was very impressive. I'm waiting for the inductors to arrive to complete the DIY. Money spend for everything (inductors included) 18euros (with post expenses) for the Lepai amp & about another 12euros for the rest.
Seriously ! I can't believe my ears. This is one of the best inexpensive little amps I've ever heard (but you have to do the mods).
Vassilis
Old 4th December 2011, 08:21 AM   #992
Tripath is amazing isn't it! Enjoy the music.
Regarding power supply voltage - the TA2020 chip can take up to 14.6V. That's a difference of about 1.7dB headroom. It's not super important, but if you can push the voltage higher than 12V "for free" on your converter, then it's worth doing — IF the other components can handle it (at least a question of the capacitors' voltage rating).
And I must say, sorry for the preaching but I have to - that I find SMD components much easier to extract than through-hole (And soldering them easier too - smd is harder at first, but after reading a little up on techinque and getting the right tools, SMD is actually wayyyy faster and easier!)
Old 6th December 2011, 10:56 AM   #993
Franfj is offline Franfj  Spain
The previous version at least has a Zener diode to "protect" against more than 13.5v, so isn't recommended going with more than this, some people say that could damage the board because of the lack of protection in the outputs.
On mine's now I have the decoupling capacitors changed by MKP 2.2uf (the ones before were 3.3uf although on the board is clearly printed 2.2, WTF??), and the sound improved a so much that I can't believe that.
Also have added another cap parallel on the power input, so now I have the 3300uf + 6800uf, and the power led doesn't blink like before.
Old 7th December 2011, 09:52 AM   #994
Just one hint if anyone has the same problem as me, the amp started to make constant pops after changing caps. It doesn't enter in fault mode, just overload.
What happened is that the resin from the solder wire created some kind of conductor between some tracks. After a lot of time soldering and desoldering, with random success (some times pops on left channel, others on the right ) cleaning the pcb with alcohol solved the problem
Old 12th December 2011, 02:18 AM   #995
pkozul is offline pkozul  Australia
Default Toroidal inductors
Hi all,
Just saw these go up on eBay yesterday...
Coils sets for Tripath TA2020 20W Class-T Digital Audio Amp upgrade. | eBay
I asked the seller for the specs, and he replied with this info:
"Hello, this is 10uH, 5A. & very low resistant. We test all with other LCR Meter before ship."
Seems like it's worth a shot, eh? Cheapest toroid option I have seen so far.
Pete
Old 12th December 2011, 05:56 AM   #996
Default another one !
Well I just bought these : http://www.ebay.ie/itm/260512722675?...9#ht_607wt_833 but i'm still waiting for post to arrive.
The ones you are looking should be fine. If you buy & test them just share your opinion with us.
Originally Posted by pkozul View Post
Hi all,
Pete
Old 14th December 2011, 02:52 PM   #997
I did the last mods on m lepai's lp2020a+. Looking at the output stage noticed that there is a smd cap just after the inductors. Well I have no clue what they intended to anchieve with that cap there but my guess is that it is their EMI output filter and they placed it right there before the output caps. Also the zobel cap on mine had one 0.47uF cap instead of 0.22uF. there we go:
I used 10000pf 5% polystyrenes that I had around for C40 but you can use multilayer ceramics.
If you're going to use it as power amp you better replace R8 and R10 with 22k or 39K low noise resistor. Much better now .
On one of my units I did the bypass and added a volume pot following Pano mod for sonic impact. Great reading there.
If you want add the volume pot after you did the bypass on Lepai Lp2020A+ you should look at the image bellow.
Old 14th December 2011, 03:48 PM   #998
One doubt, which one will be better?
ALPS RK14
ALPS RK27
The first one is cheaper (about half the price of the second). Everybody uses the classical blue ALPS, but they both seem tho have the same specifications on the ALPS website, plus the first is smaller and looks like a newer model…
Old 14th December 2011, 10:11 PM   #999
ALPS RK14
ALPS RK27
You can stick with the one that came with the lepai, it works just fine. Anyway if you think the lepai is worth of an alps pot you may get this one
Old 15th December 2011, 12:17 AM   #1000
The one about what I am taking is this http://www.ebay.es/itm/170683788782#ht_1944wt_1117 only 7$
My Lepai volume potentiometer is a piece of crap, its not centered, makes noise using it, and the knob moves in the vertical axis by 1mm u_u
But thinking about it, I think that better will remove one of the tone potentiometers and replace the volume by one of them.
Another question, what do you think about wood enclosures?, I'm thinking about making a simple one, just to improve the amp appearance. Will be needed to make some kind of metallic cover for the amp to avoid EMI?
New ta2020 pcb'S ArjenShenzhen Vendor's Bazaar 98 14th November 2012 11:39 AM
Ta2020 Bengali Class D 0 29th September 2007 05:28 AM
Eb-ta2020 opentop Class D 16 30th May 2005 07:42 AM
Copyright ©1999-2017 diyAudio
