New TK2050 board
New TK2050 board
Old 8th November 2010, 01:20 PM   #1021
alkasar is offline alkasar  France
take look at the DDX 2.1 project http://www.diyaudio.com/forums/class...ml#post2357721
However, in my experience with T2, with proper power supply and proper drivers, plenty of bass available and you won't need a sub any more
Old 8th November 2010, 01:23 PM   #1022
smithie is offline smithie  United Kingdom
hi jean paul
thanks for your comments.
at the end of the day its that good old compromise situation we all have to face in this game,i havent found one topology that suits what im looking for in my system,thats why im using valve amps and solid state,its been the best compromise for these ears so far,but im always on the look out and keep trying in the hope that i can find "the one that does it all"
all the best
smithie
Old 8th November 2010, 02:19 PM   #1023
hi alkasar
i read up on that ddx 2.1 project and i shall be keeping a eye on that...all good stuff.
regarding the subs,i cant get rid of them due to the nature of my speakers,the main drivers will only go down to around 50hz and thats proberly at a few dbs down so the subs will always be apart of the system unless i go a totally different approch which im not about to do at present.
all the best
smithie
Old 8th November 2010, 03:49 PM   #1024
Nick122147 is offline Nick122147  China
hifimediy wrote earlier somewhere in this thread that the v2 amp does not invert the phase.
Old 8th November 2010, 04:05 PM   #1025
Havoc08 is offline Havoc08  Denmark
Send a message via MSN to Havoc08
Even if it did, isn't the fix just to invert cables on one of the amps? Using a Phase test file if in doubt?
Smithie how loud do you play because with so efficient speakers T3 seems quite overkill?
Regarding T-amps I am no fan-boy of either topology and mainly only look to sound quality and of course price. Since I tried class-T I cannot go back. To me the sound is pleasent with no sharp highs and pleanty lows (D-amps were in the beginning mostly for sub amps AFAIR), imaging is superb and the background (noisefloor) is very, very low. Even my mother could hear how quiet and calm the stereo image was.
At the price of these amps and T amps in general, I have yet to find a better bang-for-the-buck.
This is of course purely subjective, but people in general seem to agree (see the Sure thread also).
If you are unsure, buy the T1 amp first and try it out with a left over SMPS from your laptop or similar.
Old 8th November 2010, 05:50 PM   #1026
hi
i got the impression(maybe wrongly) that the reviewer was talking a little more then just phase reversal problems otherwise i dont understand why his mentioned it because as pointed out its just a quick cable swap to cure..heres the quote
" But in the past, the phase issue that most class-T amplifiers seem to exhibit (only when used in a multi-amped system) had meant that they did not match well with the class AB amp driving the augmenting woofers in the Hawthorne Audio Duets."
has i have no clue on these amps i just assumed he knew a little dark secret that wasnt talked about...so obviously not then!
havoc08 thanks for your input and thoughts,i realise at this price and from all you guys ravings that these are indeed very special and excellent bang for the buck but what im really after finding out is...are they a replacement for the serious stuff? let me put it another way...how many of you have dumped your audionotes,vtls,boulders,krells etc since using these and would never dream of going back???
regarding going alittle over the top on my choice of t3 amps,that may seem the case straight off,however its just a case of keeping my options open as i have plenty of other drivers that are alot more tricky to drive and by going for these it would keep my options open and being able to try them if i so wanted...you know how it goes!
all the best
smithie
Old 8th November 2010, 06:26 PM   #1027
kristleifur is offline kristleifur  Iceland
Here's a comparison of a 41Hz Truepath, a TA3020 amp, with a Mark Levinson, a Briston, and a Nelson Pass amp: Clash of some Titans
Old 8th November 2010, 07:18 PM   #1028
hi thanks for the link
found the shoot out abit meaningless as the amps in question where all pretty old and at a time where ss wasnt at it greatest,intresting that it was also the time i switched to tubes/valves
anyway time to order something i think and find out for myself,thanks for all your help guys
smithie
Old 8th November 2010, 08:00 PM   #1029
datawolf is offline datawolf  United Kingdom
datawolf's Avatar
Got my V 2 board the other day and it sounds amazing.
I do have a problem though... when I connect my REL 'Quake 150E' subwoofer to it I get a high pitched whistle sound.
I'm only connecting the sub to one channel out of the amp.
Anyone got any ideas what the problem is?
Old 8th November 2010, 08:14 PM   #1030
bigaudioscotto is offline bigaudioscotto  United States
Is this a powered sub.
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 31st May 2011 12:06 AM
Any input on the new Dayton TK2050? finnbow Class D 10 3rd May 2011 12:37 AM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 06:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 08:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 12:06 PM
Copyright ©1999-2017 diyAudio
