| Class D Switching Power Amplifiers and Power D/A conversion |
| Thread Tools | Search this Thread |
#363 | |
It looks like he's getting about a 4ohm load with 2x8ohm DAYTON PA130-8 5" speakers in parallel. |
#364 |
Doesn't the woofers present (8*8)/8+8= 4ohm and the tweeter 4ohm resistor + 4ohm speaker = 8ohm making the whole circuit (8*4)/8+4 = 2,66ohm ?
#365 |
I am going to build one myself with a 10 dollar tripath 25W amp. 50 hours on a standard battery? That's a lot of Combichrist!
Almost this one, without the box: http://cgi.ebay.com/Excellent-2-1-CH...3A1%7C294%3A50 I am thinking about a mono bass 12" driver on one channel and another channel with a 90's low-fi panasonic 3-way speaker with 10", 4", 2" drivers. Power is from a normal sized 12V battery. I really don't care about hifi, not even about stereophonics. I guess we can't play 60's beatles with guitars on one channel and drums on the other. As if we would want to on the best synth festival in Scandinavia - The Arvika Festival! Fy fan! |
#366 |
Hi Rewind,
Those 3 channel amps are class A/B, they don't use the Tripath TA2020 chip and they are not class D so they will be less than 30-50% efficient. The Class-D are up to 90% efficient. There is some more details of the chips they use in this description: http://cgi.ebay.com.au/New-Lepai-LP-...rkparms=65%3A1|66%3A2|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50 col.
http://www.minirig.org.au |
#367 |
That's good to know, because I almost ordered one of those instead. I actually have the two channel tripath version TDA2030. I do need a basschannel så I will only use one channel for a 12" driver.
I wonder how loud a 12" bass driver with 91dB/W on a 25W tripath will get. And is the 50 hour batterylife on a 550mAh battery correct? |
#368 | |
#369 |
Hey guys, I see my pet project is still making a stir.
![]() I'm sorry I haven't been around to answer many questions lately. But in the next couple of days I'll back check and answer a few of those I can answer. Firstly regarding the resistors on the piezos, they don't have to be the value I used unless you use the exact piezo use. The value can be calculated as the capacitance of the piezo and the resistor form a high pass filter, that should have a corner frequency of about 3.5-4KHz. High quality piezo like the ones I used generally but not always have much higher capacitance than low cost piezo so the resistor is of much higher value. I recommend NOT using wirewound resistors at all, these have much too high serial inductance, and in series with a piezo that forms a low pass filter. Even Dale's super expensive "non-inductive" wirewound power resistors have too high series inductance. Use 3W carbon or metal film resistor instead, or several low wattage resistors in parallel. |
#370 |
Secondly, the concept behind the Boominator depends 2 things mainly. The bipolar design which means a lot of leveling over the frequency band comes is completely automatic since there no baffle step to consider. And then a little trick I discovered after having built several test cabinets. If you calculate a standard optimal bass reflex cabinet for whatever driver you use with the optimal Q=0.7 tuning, and you then divide Vb with PI, and multiply Fb with the squareroot of 2, you end up with the optimum tuning for outdoor use Q=1.2, and you get rid of all those bass frequencies you can't play loud enough to be audible outdoors anyways, and at the same time the rise towards the cut-off frequency equalizes the bass to a more or less flat level when used outdoors.
| Page generated in 0.12305 seconds (64.79% PHP - 35.21% MySQL) with 11 queries |
