Old 19th March 2010, 02:01 PM   #1361
StigErik's Avatar
Originally Posted by sasmit View Post
I bet they do ... u should also have 0.1 uf soldered right onto the last caps ...if u don't have them already
Yeah, I had them close to the LM3886. Everything was hardwired by the way, no PCB. The amp had just one channel by the way, a single LM3886 and a very big PSU.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 19th March 2010, 06:33 PM   #1362
robertor's Avatar
Send a message via Skype™ to robertor
Default Lm1875 ciciop
Lm1875, the little brother of Lm1876(ouverture serie national).
rob
Old 23rd March 2010, 05:52 PM   #1363
Here is my LM3875 Gainclone amp:
The aluminium parts
Half of the assembly (home made amp PCB)
Both amp PSBs in place
DC protection board with power LED attached
Another project of mine: (a very big one at that!)
http://www.mp3car.com/vbulletin/show...5-pimping.html
Old 23rd March 2010, 06:04 PM   #1364
troystg is offline troystg  United States
troystg's Avatar
Not bad work with the gainclone, but AWESOME work with the van!! Holy crap!!
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 23rd March 2010, 06:06 PM   #1365
Cheers troystg. The van was a big old project
Old 23rd March 2010, 09:56 PM   #1366
Had to add another post.....
I have been listening to the amp all afternoon and was so amazed at the quality that can be obtained from such a minimal amount of components. I was convinced that it sounded better than my Denon amp, so I called a friend to come and audition it. He brought over some well recorded orchestral music and after half an hour of listening, is convinced that it sounds as good as his £3000 Arcam setup. He said he was stunned at the ease of listening of the music produced.
Can anyone else comment on comparisons to other high end audio equipment? I've only used cheap components in the amp and can't wait to build some mono blocks with higher quality components.
Old 23rd March 2010, 11:04 PM   #1367
udailey is offline udailey  United States
Passive Aggressive
It just flat out DOES sound better than a lot of high dollar stuff. A badass power supply can make it even better. Something like the F5 supply is really nice. I finally like my new build. I used the Gold Tone caps in power supply from Nichicon. It took a loooong time for them to loosen up but finally things broke through and the veil it had is gone. I like Panasonic FC on the 100uf if you used 100uf on Pins 1,3 and 8. They are super detailed. Some say to harsh. I like it that way I guess. However while this smokes a lot of silicon amps in the stores most tube amps I have listened to in the past few years have beat it handily. Not cheap tubes mind you so for sure the chip amp wins out over the tubes in sound quality per dollar.
Nope, dont have specific amp references.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 23rd March 2010, 11:25 PM   #1368
Thanks for your reply udailey. What do you mean by an 'F5 supply'?
At the moment, my power comes form a toroidal transformer feeding 2 cheap bridge rectifiers. The output of these goes straight to my amp PCBs. I have no smoothing caps at all on the power supply, and all of the components used on the amp boards are standard cheap ones. The idea of this first build was to see the music quality achievable with basic parts.
My plan is to replace my Denon 7.1 surround amp with a cheap pre-amp, capable of AC3 decoding, and drive my speakers with mono blocks built from LM3875s. Has anyone had any experience with 'HLLY High End DTS AC3 5.1'?
Old 23rd March 2010, 11:48 PM   #1369
Pato666 is offline Pato666  Argentina
Send a message via MSN to Pato666
WOW, you're a PRO!
VERY GOOD design!
Thanks for sharing, that can give us ideas. I loved your pimped van also, very nice post!
did you milling all the aluminium parts by yourself?
Regards.
A word about me and my projects http://www.cristianortegadelrio.com [Brand new site!]
Old 23rd March 2010, 11:57 PM   #1370
Hi Pato666. The milling was done on a cheap pillar drill with an end mill in the chuck.
An example of how I produced the hole for one of the phono sockets:
1. Drill a 6.5mm hole through the aluminium
2. Use a countersink bit to expand the hole to about 21mm
3. Use a 20mm end mill to mill the hole to the desired depth.
The countersinking bit is used to give the end mill a bit of guidance. Without the angled sides that the countersink bit makes, the end mill (when used in a cheap pillar drill) seems to bounce around and doesn't drill very well at all.
Page generated in 0.19828 seconds (38.50% PHP - 61.50% MySQL) with 11 queries
