| Chip Amps Amplifiers based on integrated circuits |
it is a chip based op amp plus buffer ic design.purpose for genus use.
the archetype url: http://www.diyaudio.com/forums/showt...554#post179554 here is my finished amp,to feed my hd495 headphone.it has fine lowZ performance. http://www.diyaudio.com/forums/showt...057#post362057 I transform it into PCB layout now. |
#2 |
BOM list,
U1,U2- opa637 pdip U3,U4- buf634 pdip package *R1,R5- 220K 0.25W(for gain setting) *R2,R6- 39K 0.25W(for gain setting) *R3,R7- 1K 0.25W *R4,R8- 47K 0.25W *Ra1,Ra2- 1.5K 0.5W Rb1,Rb2- (for buf634 BW setting) CA1,CA2- 6.8uf/63V film caps or 33uf/35V aluminium cap sch file attached
#3 |
Electrons are yellow and more is better!
digi, you shuold add a cap (according to the datasheet of BUF634) between the output of the opamp and the inverting input. If you do this, your design will be more universal.
You also add a resistor for the BW pin so you can tune the bias current. Also for more flexibility. OPA637 is not so good in low gain applications but this you know already? OPA627 is better. I see that the gain is 5.6 so a OPA637 will handle this but the pashe amrgin may be a bit too little. I would have chosen an OPA637 if the gain was 10 or more. 220k + 39 k is pretty high, both for noise (probably not an inssue) but I'm thinking of more of effects of stray caps and problem with stability. Why don't you lower these values to 10 k + 2.2k or even as low as 2.2k + 390? Since you have a buffer you really can "afford" these low values. Add also decoupling at the supply pins, like 100 nF/63V Polyester, ceramic. Avoid to use only a 6.8 uF film cap because they aren't so good high up in frequency. I would also make the feedback path storter. Try to turn the feedback resistor. I would not have drawn the power traces under the IC's. I would have used this space for signal traces instead. Strive to get the groundplane as "whole" as possible. Avoid traces which divides the groundplane. Inspiration can be found here. Just want to add that my headphone amp which is OPA627+BUF634, or AD8610+BUF634 is excellent. I have also tested OPA134 and I thought it did well also... so this buffer digi01 will be a success I'm sure.
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
Hi digi,
I'm trying to work out where CA1 and 2 fit in on the schematic? (Yeah I know, I'm not so clever... )
"Everything should be made as simple as possible, but not simpler." - Einstein |
#5 |
your not alone Mr.Falcott.. it appears not all parts listed in your previous post are accounted for in the schematic?
regards marius |
#6 | ||
thank you P-A,I will revise the layout in accordance with your suggestions.your smd version is wonderful BTW.
here is the all parts schematic,the CA1/CA2 6.8uf caps is set up for the power rails. beside the power circuit,you hardly find a cap in the all buffer circuit(the Cd1/Cd2 is added according to the suggestion of P-A). enjoys digi |
#7 |
Digi, look atentionaly at this schematic : if you can to get lowest distortion, impedances on both inputs must be the same. This connection have the same AC and DC conditions on both.
#9 |
Yes, it is long time well known
. Look at PCB .
#10 | |
| What is a CD Audio Buffer? | chofaichan | Digital Source | 18 | 5th April 2009 08:27 PM |
| Audio buffer amplifier | cumesoftware | Solid State | 28 | 16th June 2008 09:41 AM |
| JL Audio Mainboard Layout? | XxGoKoUxX | Car Audio | 9 | 20th February 2008 03:33 AM |
| PCB layout for audio | panson_hk | Solid State | 34 | 3rd September 2007 10:08 PM |
| Page generated in 0.10572 seconds (80.56% PHP - 19.44% MySQL) with 11 queries |
