| Chip Amps Amplifiers based on integrated circuits |
#21 |
The only paper I've had "melt" is the inkjet iron on stuff for making t-shirts and that sort of thing.. didn't do any harm to the printer, just under heat the toner didn't stick to the paper, so I had to run a bunch of normal paper through after to pickup the toner.. but this inkjet coated semigloss works great.. there maybe better paper, as I haven't tried much..
#22 |
I've made many homebrew PCB's.
I've recently gone from the Kepro negative DF boards to a positive process with fantastic results. Get the material and chemicals from Parts Express....inkjet a film pos on transparency film at 2880 dpi.... and that's it. |
#23 | |
Here’s an example of silkscreen I have done this way, except I use plain paper for this, as quality of the silkscreen isn’t of that big importance to me.
Sven Sødem |
#24 |
hey, black looks more pro-er (don't laugh) than nothin...
can everybody please give me their opinions on the absolute best paper to use?? How about the hp or epson i talked about earlier??? Also, can this work for surface mount chips? I am designing a surface mount headphone amp using the lm4881M, so I need to be able to make small traces perfectly. i picked up a couple sheets of transparency from kinkos, is it worth trying at least? thx, mike |
#25 |
oh and what about the protective/nice looking coating?
#26 |
My old method involved printing onto a sheet of sticker backing, when heated up the ink would come right off the waxy like surface and stick to the pcb!
worked like a charm.. now i have access to a mill
#27 |
My 2c:
I know you're not looking for a "photo" process, but I find the positive photoresist boards very easy to work with. DSE in NZ have or at least had a green spray (aerosol) that you can paint copper with - or buy presensitised Kinsten board which is cheap enough. I have settled on using an inkjet printer (better accuracy, better contrast, very fine tracks) onto thin photo quality paper (not transparency), lining up and taping print side together against a window (for 2 sided boards). This goes in the UV exposure box (the tricky part - vaccum bag hold down and UV lamps top and bottom) for 5 minutes. Develop in solution of NaOH 5g/L lukewarm water. Etch as usual (hot ammonium persulphate in a bubble tank). I think the fastest I've done this part from print to ready to drill is 20 minutes or maybe that even included drilling (we used to have races). Drilling is the horrible part for me - I've got a DIY CNC router but it's a pain to set up. If drilling manually I like to use worn (throwaway) carbide drill bits because they self centre easier in pad holes. All hell breaks loose when you break your last drill bit on a weekend. As for protecting the boards, I either leave the photoresist on, or spray with plasti-kote clear acrylic spray. |
#28 |
ok, thanks, but i am sticking with the toner method, nothing is going to change my mind.
the sticker thing sounds interesting. can i use ordinary wax paper? |
#29 |
o can i get rid of the toner except on the pads, spray it with the protector stuff, then remove the toner on the pads so everything is protected except the pads?
hopefully this makes sense |
#30 |
Your wasting your time with ANY method other than a photo process.
Why? Because any other method gives INFERIOR results. Been there....done that. FYI. (You're welcome). |
| FS: Aleph-X PCBs , NIGC PCBs , OPA541AM OpAmps | e.lectronick | Swap Meet | 25 | 6th March 2013 07:40 PM |
| Making PCBs - Silicate Developer | Devil_H@ck | Parts | 15 | 22nd April 2012 06:23 AM |
| Making pcbs, another guide | takeda | Everything Else | 1 | 31st March 2007 09:01 PM |
| Trade Aleph X PCBs for Aleph P 1.7 PCBs | highbias | Pass Labs | 0 | 27th September 2004 05:59 PM |
| Tutorial: Making PCBs | Devil_H@ck | Parts | 19 | 10th May 2004 05:51 PM |
