Rocford punch 500-2 2007 model.
Opened the case and all four ps fets blown and rectifiers were burnt also the source leg on them is black. I don't know how to test them?
The drivers , Q103, 104, 105 and 106 on the river board will need to be replaced.
If you remove them, you should read about 5v on pins 9 and 10. After replacing the drivers, you should read approximately the same on the gate legs of the power supply FETs.
Do NOT connect B+ to the amp until you get good driver voltage at the FETs.
