The suggestion for biasing was before you posted the DC offset problem. Bias won't cause DC offset in these amps if the bias setting is the only problem.
You generally cannot use the original bias setting after replacing output FETs. After replacing outputs, set the bias fully off (CCW in these amps) before powering the amp on.
Low unless you have a reason to set them high. Higher bias will make the amp run higher, often with no benefits.
Set them like this:
http://www.bcae1.com/temp/ausettingbias.swf
Set them like this:
- General Interest
- Car Audio
- Rocford punch 500-2 2007 model.
