Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 27th May 2008, 05:16 AM   #81
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
We can also notice that with volume turned down, the rails are at 32.6V DC. So under full power they drop by 2V.
To order kits contact me through forum mail.
Old 27th May 2008, 05:56 AM   #82
I do the same test for 4ohm load (8 resistors in parallel) and initially we can see 56W power output with rails going down even further to 29.5V.
Old 27th May 2008, 05:59 AM   #83
However, as the heatsinks warm up (and it happens really fast), the power colapses down to 10W or so. Those heatsinks are definitely not suitable for 4ohm loads under full power.
Old 27th May 2008, 06:11 AM   #84
The frequency response is approx 4Hz-240kHz (-3dB)
Old 27th May 2008, 06:22 AM   #85
There is one other thing we can check tonight: lets disconnect one of the rails and see what happens with DC offset.
I disconnect the negative rail first.
Old 27th May 2008, 06:24 AM   #86
Without any load connected, we measure 31.7V DC at the output.
Old 27th May 2008, 06:44 AM   #87
After we connect the dummy load, the DC offset drops down to 75mV. In my test, it does not happen right away though, but takes approx a second or so for the voltage to drop.
I did try it with a test speaker and unfortunately the DC voltage was still present (at 24V or so)
Old 27th May 2008, 06:53 AM   #88
With positive rail disconnected and no load the DC offset is approx 7V.
Old 27th May 2008, 06:58 AM   #89
With test speaker connected, the voltage drops immediately down to 70mV and there is no danger whatsoever to the speaker.
The above findings are quite interesting and surprising. It was reported few times on a forum, that there is no danger to the speakers when one rail disappears, however, it seems like this is only the case with the positive rail. With a negative supply disconnected, I couldn't eliminate DC offset with my test speaker, although with a dummy load, the offset was going down indeed.
That Blaupunkt car speaker took 24V for at least 4 seconds many times over and still didn't suffer any damage
Old 27th May 2008, 06:04 PM   #90
sneih is offline sneih  Indonesia
sneih's Avatar
thanks bro....
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
