Angling for 90 - tangential pivot tonearms - Page 11 - diyAudio
Old 26th January 2011, 08:55 AM   #101
Old 26th January 2011, 08:59 AM   #102
Default RS Labs clone
Old 22nd April 2011, 09:23 PM   #103
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by directdriver View Post
More experimental tonearms. I am going off on a tangent here, pun intended. These have nothing to do tangential tracking. I believe it's about using string to deal with tracking force to lessen the moment of inertia from the ubiquitous counterweight. As you can tell, some of these arms use recycle parts from other arms.
It was inspired by the(47 Labs) RS Labs RS-A1 tonearm. Here's the text on the website via Google Translate:
I'm not sure any of these work at all as tonearms. Apparently this is just one big experiment and we never saw the final product as can be seen in this series pictures in historical context: What disappointment!
More images from Russian site
Click the image to open in full size. Click the image to open in full size.
Can this last one work ?
I am also puzzled by the swinguing headshells you posted earlier. Can they improve tracking and reduce distortion ?
Ricardo
Old 22nd April 2011, 09:37 PM   #104
nhinstruments
RCruz's Avatar
These are puzzling me... Does the idea work ?
Old 24th April 2011, 01:42 AM   #105
directdriver's Avatar
RCruz: "These are puzzling me... Does the idea work?"
That's a loaded question. Please go back to earlier posts to explore more. The RS Labs examples are not intended to correct offset angles or to reduce tracking error so it's really not about tangency. But it is intended to reduce skating force.
Check here: www.sakurasystems.com/products/rsa-1.html
The tonearms that are intended be tangent can be examined in posts about the Thales tonearm and its theories. If you have time, go through the entire thread.
Old 24th April 2011, 10:45 AM   #106
nhinstruments
RCruz's Avatar
I allready read about the Thales tonearm that I had the oportunity to see and listen to in Krefeld during tha AAA show last october. I works ok but is very complicated.
I was puzzled about the head shell contraptions but you made it very clear now.
Thank you so much.
Old 25th April 2011, 12:22 AM   #107
RCruz: "I was puzzled about the head shell contraptions but you made it very clear now."
I think I included the link with the simplified answer. Here's a more elaborate piece: www.sakurasystems.com/articles/rs-a1.html
Old 25th April 2011, 10:10 AM   #108
nhinstruments
RCruz's Avatar
Thank you directdriver.
Now I see the point in using a high pivot
Old 26th April 2011, 03:37 AM   #109
Default Thales Simplicity tonearm pix
More nice pictures of Thales Simplicity tonearm. I think I like this arm even more than the flagship model.
__________________________________________
Old 26th April 2011, 04:29 AM   #110
Default more Thales Simplicity tonearm pix
***CLICK*** Read about the Thales principle ***CLICK***
Gliding for 90 - mechanical linear tonearms: no airpump, no servo directdriver Analogue Source 33 3rd April 2016 11:40 PM
Angling of ports and/or drivers? Dave McReeferson Full Range 11 27th March 2012 07:45 PM
String suspension vs. uni pivot or gimball tonearms nghiep Analogue Source 26 13th August 2011 04:27 AM
Angling drivers left and right in a vertical line-array???? ozziozzi Multi-Way 12 16th January 2009 04:23 AM
Need Amp For 90-0-90 V DC Drafance007 Solid State 15 12th October 2003 08:03 PM
Copyright 1999-2017 diyAudio
