| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#31 |
I think the only way is to listen. I found that also the type of resistor is important.
The best sound i got so far is with DaleRN65E. I the case of a conventional input i landed between 150 and 300 Ohm in parallel to the cartridge with Lyra Titan i. If i understand your circuit right you have not the same impedance in both legs. Taking my variety of your circuit the positive leg whould see 5 ohm and 150 Ohm in series when i ignore the ( high ) input impedance of the positive input of your opamp. The negative leg goes to a 5 Ohm resistor and then to virtual ground so your Koetu whould be loaded with 160 Ohm because both inputs are in seies. Do i see that correctly ? |
#32 | |
In my opinion the input impedance is 102.2ohms (51.1+51.1). As the voltage difference between +in and -in is virtually zero, it may be seen as a shortcut, and thus the feedback resistor and ground resistor are no part of the input impedance equation. Mmm… (I think). Regards, Frans. |
#33 | |
) and found:Operational amplifier applications - Wikipedia, the free encyclopedia Near the header: Differential amplifier Regards, Frans. Or am I way out of line here, and did I read your post wrongly?
#34 |
You are right.
Differential Zin (between the two input pins) = R1 + R2 (Note: this is approximate) |
#35 |
Yes, the internal impedance beteen Pin2 and Pin3 can be interpreted as a short circuit.
#36 |
Is the best digital sound ever heard till today, now I'm upgrading with film cap in VRef by Salas advice, Salas v1.0 reg with Rs feeding the Buffalo II DAC + passive resistor + coupling cap as suggested me Erno Borbely for I/V (only penalty low gain)while I wait for the modification in his I/V that I own, so the final setup will be Buffalo II DAC + Erno Borbely I/V.
#37 | |
can you show the complete functional connections of Salas shunts ( how many - how do you connect to Buffalo ) etc Is there a photo? thanks as I am interested to build one kannan |
#38 | |
The question remaining, and that I would like to see answered, is this; is using lower value resistors a tradeoff between noise and impedance matching? And to what effect? The bottom line is; what am I paying for the lowered noise floor? Regards, Frans. |
#39 | |
The photo with passive I/V (resistor+coupling cap) few post ago. The Buffalo II only needs a single +5.5V rail supply so only you need to do a Salas reg. p2p like mine photo or buy a Hipnotyze PCB in the GB. |
#40 | |
| RIAA with balanced output? | roger-k | Chip Amps | 4 | 1st May 2010 11:27 PM |
| DC on preamp input | sharpi31 | Tubes / Valves | 10 | 4th May 2008 02:19 AM |
| Single-ended input to balanced output, no DC offset | LineSource | Solid State | 16 | 19th October 2005 09:32 PM |
| OPA1632 for balanced RIAA preamp.? | Ultima Thule | Analogue Source | 1 | 7th June 2004 09:06 PM |
| Balanced DC servo for balanced stage ? | CheffDeGaar | Solid State | 8 | 9th July 2003 02:39 PM |
