MPP
MPP
Old 30th December 2009, 06:52 PM   #581
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Hi syn08 !
I will measure the voltage on my speakers at that volume we listened.
My speakers have 86dB 1W 1m sensitivity have 8Ohm impedance and i am siiting around 1.8ms from the speakers.
Old 30th December 2009, 07:04 PM   #582
syn08 is offline syn08  Canada
Originally Posted by Joachim Gerhard View Post
Hi syn08 !
86dB is really low sensitivity... 11dB less than my horns, this pretty much covers the gap.
Old 30th December 2009, 07:06 PM   #583
Ikoflexer. in the new year i will make PCBs. The MPP Low Z is finished and i have several conventional and inductive RIAAs where the last problem is some hum infusion into the coils. i am working on it. There will be a high Z MPP with FETs. I ordered some preselected ones from Borbely but he is bussy with other things. I will now order some elswhere and do the measurements myself. I am working on the shunts that Salas designed. I did also a fitting speaker (Dipol, 95dB sensitivity) and have a class A single ended Poweramp under way. I build my version of the B1 that fits well too. Then i have the subsonic filter and the cutter head compensation. I just have to present it here in a form that allows building without problems. I will sell stuffed board but will not offer kits. I have no time for a lot of aftersales service.
Old 30th December 2009, 07:12 PM   #584
Originally Posted by brianco View Post
@ ikoflexer
Thanks brianco, you are entirely correct. FYI, ikoflexer is for quite some time on my ignore list (therefore I'm not reading his posts, and obviously I can't and won't reply directly).
Old 30th December 2009, 07:43 PM   #585
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
And so it goes.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 30th December 2009, 07:55 PM   #586
I will help if i can. I will make some of the PCBs availabe with shematics and BOM but not kids with all the parts.
Old 30th December 2009, 08:19 PM   #587
The noise is 10mV maximum at the speakers so syn08 you came close. Sitting alone in the evening i can barely hear it. It is extremy quiet than in my small vilage. During the day i can not hear it. It is much lower then the hiss of 95% of the records though. I can not win a noise contest with the ECHO but it is as good as most low noise Opamps and costs vitually nothing. Sound is very good too. Very transparent with robust and fast bass and fundamental tone area. it has great dynamics too. This is an entry level circuit and i can do better and have shown it here. My best circuit is 0.5nVQHz right now but i will try to reduce that to find out if that sounds any better.
Old 30th December 2009, 08:32 PM   #588
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Holger Barske View Post
Hmm... All of Joachim's attachments open without any problem here. You are for sure using the latest Acrobat Reader?
Thks for answer, yes I am using the last version 9.2
Old 30th December 2009, 08:49 PM   #589
stinius is offline stinius
Originally Posted by scott wurcer View Post
Old 30th December 2009, 09:39 PM   #590
I do not have a DIY business yet and when, what do you have against it ?
Or did i understand that hint wrong ?
MPPHide this!Advertise here!
