Old 17th September 2012, 12:05 AM   #8011
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I was doing some phono related stuff too. Was checking the bias for the experimental ones. I put the two stages together with the Riaa in between. Not too bad the sim models, they only showed 1V more load drop in the second stage. Gain was spot on. So I trimmed the values around it a bit to center the buffer best. It gave ~20 Volt peak to peak before compression started kicking in. I have noted the practical values in red, should be the same for all such example schematics discussed, they share the same second stage and B+. If choosing 7.5mA Idss Q5 & Q6, R11 can be 1.5K. Q3 can be a bit slack for exact Idss choice due to enough degeneration from R8 that takes it near 3.5mA. Looking for ~23V drop across R10 should be that stage's channel matching criterion.
Old 17th September 2012, 02:16 AM   #8012
Rush is offline Rush  United States
Originally Posted by Salas View Post
Ooops! Another one baby. Look at those lights! Very nice job that you won hum in this combo. Plus you say you like it, so only remains I wish many nice & relaxing vinyl sessions.
P.S. What TT, cart, speakers?
I have two sets of speakers both Snell E and E2. The E is bi-amped with a slightly modified Rane AC22, a pair of stereo F5s the E2 has standard internal crossover. I guess I like the Snell E speakers.
The Turntable is a Technics SP10 II in a custom plinth made out of a mixture of kitty liter and isophthalic resin poured into a hardwood frame (to make it pretty) and an Eminent Technology ET2 air bearing arm and a Lyra Delos cartridge. The arm is wired with Van den Hul silver 150 micron.
The audio wire I used in the pre amp is also Van den Hul 300 micron silver.
Here is a photo of the turntable/arm/cartridge.
Rush
Old 17th September 2012, 02:46 AM   #8013
Salas's Avatar
Looks like a good vinyl transcription source.
Old 17th September 2012, 04:05 AM   #8014
Salas's Avatar
What other phono pre you used for the Delos?
Old 17th September 2012, 04:29 AM   #8015
The Delos is new, it replaced an 20 year old Van den Hul MC10.
I was using 2 different tube pre amps. A Counter Point SA-7 most recently and a home designed and built DIY rig built years ago. I borrowed pieces from all around and sliced them together. Made a nice sounding pre amp for 15 years. It uses 7308 phono tubes with a ccs (k389 I think), 6FQ7 line amp.
I also have a Audio Research SP6 modified with a new soft start stable power supply. Haven't listened to that in years.
The Counter Point I pulled out of storage when I detected some distortion in the home built unit and realized I couldn't find the schematic.
That's what started me on the quest for a better RIAA phono. And it just grew and grew. Now the pre amp box will be full, so that will be that when the Hypnotize boards are stuffed and the cover can go on the pre amp for good. (For good?)
This RIAA phono is very quiet compared to the tubes. Everything is Crystal clear, wide image, no harshness. I like it.
Rush
Old 19th September 2012, 01:35 PM   #8016
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Hi Salas
In the case of cascoded 2nd stage, miller is reduced so input capacitance of this stage is around 30pF beeing equal to the k170 Ciss right ?
RC
Old 19th September 2012, 04:11 PM   #8017
Salas's Avatar
Should be down to circa 50pF remaining Miller and all at ~3Vds cascoded I measured at that bias and degeneration, but I don't trust the Jfet spice models to such a degree for giving the absolute HF response especially in the presence of a Riaa filter. We will have to normally build it, measure it and listen to it, then tweak it if necessary. I will FFT measure on the breadboard model but there are extra capacitance and inductance parasitic elements so not to fully rely.
Old 19th September 2012, 04:43 PM   #8018
RCruz's Avatar
does this miller value depend on frequency of the amplified signal ?
RC
Old 19th September 2012, 04:49 PM   #8019
Salas's Avatar
No as far as I know. At least in the audio band.
Old 19th September 2012, 05:09 PM   #8020
RCruz's Avatar
Cool... that simplifies everything.
I was mistified by the k170 pdf where we can read:
Input capacitance Ciss (VDS  10V, VGS  0, f  1 MHz)  30  pF
RC
Copyright ©1999-2013 diyAudio
