Simplistic NJFET RIAA
Old 21st March 2010, 11:00 PM   #3411
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Ok exact values as Salas designed for resistors plus 2.2Meg over 47K in parallel, for caps start with 45nF & 15nF & fine tune adding small caps.
Old 21st March 2010, 11:59 PM   #3412
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Very good but I would stick to 2M or 1M8 (even closer if you get the exact 6k8)
IMO a difference of 20ohm in the 6k8 can easily be heard.
For cap tuning always take in consideration that C2/C3 should be 2.916.
Thank you again for your input.... It prooves my calculator works correctly.
Old 22nd March 2010, 12:44 PM   #3413
How can calculate?
Old 22nd March 2010, 01:34 PM   #3414
nhinstruments
RCruz's Avatar
Originally Posted by merlin el mago View Post
How can calculate?
Always make sure C2/C3 = 2.916
IMO this relation is critical for linearity.
Old 22nd March 2010, 02:28 PM   #3415
SALAS RIAA MATCHING BY KABUSA
LEFT & RIGHT
R = 3.300+47.000 // 1.000.000 = 47.891 input Kabusa R1
Kabusa R1 47.891 - R4 6.963 - C2 45nF644 - C3 15nF661
45nF644/15nF661 = 2.92 very, very close/near your calculation
An useful calculator for capacitors in series & parallel:
http://www.electronics2000.co.uk/cal...calculator.php
Old 22nd March 2010, 02:35 PM   #3416
full stops mean what?
regards Andrew T.
Old 22nd March 2010, 03:01 PM   #3417
Kabusa Riaa calculator
R= 3.300+45.804 (47k//1Meg8) // 1.000.000 = 46.805 input Kabusa R1
Kabusa R1 46.805 - R4 6.805 - C2 46nF723 - C3 16nF024
C2/C3 = 2.92
Your suggestion is very good because maintain the R4 value 6K8 & the linearity also is very good.
So I need to match the following values that I don't have:
LEFT
R3 add 1Meg8
R5 change 1Meg13 for 1Meg
C2 start with 46nF3 & reach adding more caps till 46nF723 max.
C3 start with 15nF6 & reach adding more caps till 16nF024 max.
RIGHT
R3 change 46K8 to 47K& add 1Meg8
R4 change 6K79 to 6K8
R5 change 998K to 1Meg
C2 start with 46nF4 & reach adding more caps till 46nF723 max.
That's right?
Old 22nd March 2010, 03:03 PM   #3418
nhinstruments
RCruz's Avatar
You got it !
Just a hint.... IMO to reach C2 better value you should use three caps: 46,4n + 300p + smaller cap
It seems to work better this way and it easier to tune.
Old 22nd March 2010, 03:09 PM   #3419
Can't possible without your (Ricardo, Salas, nicoch46 & many others) help.
Old 22nd March 2010, 03:16 PM   #3420
nhinstruments
RCruz's Avatar
You will get used to it.... It seems to be a diyaudio prerogative.
It feels good to help good people
Of course, by helping the good ones we tend to learn faster.
Simplistic NJFET RIAAHide this!Advertise here!
