Balanced Line Driver with DRV134
Old 27th February 2013, 05:23 PM   #71
maxw is offline maxw  United Kingdom
maxw's Avatar
Ah OK. Then yes, just change the horizontal regulators for vertical ones using the replace tool.
Old 28th February 2013, 06:50 PM   #72
chris2 is offline chris2
Hi me again....
I fixed the board area issue by changing the regulators to some verticals ones.
Here's a snapshot of the gerber results. I'm curious what some of you might about the spacing between the thick trace below the regulator. Is the spacing there too small. It doesn't appear to be less than the spacing between the traces and ground plane. The lowest horz. blue space is about 0.166 mm high.
I ran a board houses DRU file w/o errors.
Thanx for looking at it.
Chris
Old 28th February 2013, 07:15 PM   #73
Loren42 is offline Loren42  United States
Originally Posted by chris2 View Post
Hi me again....
Chris
Just take care when you solder it so that you do not get a solder bridge.
0.166mm is very, very small (about 0.006"). It may pass DRU, but generally, such tight keep-away distances are reserved for high density digital boards with surface mount and ball grid arrays where sneaking traces between pins is an absolute necessity.
Also, board houses do make mistakes and I have seen occasional open traces, shorts, and bad vias. I have some recent boards where they simply missed one trace altogether.
Old 28th February 2013, 07:59 PM   #74
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
You should have 15 mils/ 0.3mm at least in isolation distance. It seems way to small now.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 59 paid.
Old 3rd March 2013, 12:06 PM   #75
Thanx peranders...
I cleaned up the layout a bit and did a dru.
Eagle has a default of 10 mils. This passed so I changed the settings for objects, pads, drill/holes etc. to your suggestion of 15 mil's and it passed again.
Chris
Old 29th July 2014, 11:53 AM   #76
Eastwood is offline Eastwood
Hello,
I've built a very similar circuit adapted from Chris2's final design although I used an NE5532 instead of an OPA134.
I was having an issue with DC on the output of the NE5532 so replaced the 68R resistor with a 47uF cap and a 22K DC drain resistor.
The problem I've noticed is that there is a difference of between 20mA - 50mA (I built serveral circuits) on the + & - output of the DRV134. Any idea what may be causing this?
Old 29th July 2014, 12:58 PM   #77
R.I.P.
post your circuit.
regards Andrew T.
Old 29th July 2014, 02:45 PM   #78
Originally Posted by AndrewT View Post
post your circuit.
Sorry, here you go...
Old 29th July 2014, 04:31 PM   #79
The input is taken from Douglas Self's Small Signal Audio Design
Old 29th July 2014, 05:14 PM   #80
R.I.P.
draw a sketch and post a pic.
The copyright is on his original drawing, not on your sketch.
regards Andrew T.
Balanced Line Driver with DRV134Hide this!Advertise here!
Balanced line driver (DRV134) and noise ettos Analog Line Level 34 16th October 2011 10:20 PM
Burr-Brown DRV134 AUDIO BALANCED LINE Receiver schematic PCB/Kit anybody? cirrus18 Analog Line Level 14 24th March 2010 10:10 AM
Cable for audio balanced line driver (drv134 ) fluc Solid State 3 25th April 2008 05:30 PM
is DRV134 the best balanced line driver? anli Chip Amps 4 13th December 2004 05:55 PM
Balanced Line Driver Jerry Parker Everything Else 1 1st April 2003 05:32 PM
