Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th September 2012, 05:12 PM   #1161
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally Posted by bcarso View Post
Some of us like to also confine currents to loops as local to a given circuit section as possible
This is very important Brad, thank you.
If all amplification stages are connected in series (think board level) to the PSU, local RC decoupling alone, does not.
Parallel connection to the PSU plus local decoupling does.
Originally Posted by bear View Post
hmmm... more tiny ants to herd.
Ah, now I see bear. I overlooked your true nature
George
"Second Law is a bitch." - SY
“Not to worry, audiophiles don't normally get past the Gate anyway.” - rdf
Old 24th September 2012, 05:26 PM   #1162
expert in tautology
bear's Avatar
Part of what I was thinking is if there are consequences to designing for high PSRR or not.
Does making the circuit "do work" to cancel PS "stuff" effect the desired operation, or not.
_-_-bear
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 24th September 2012, 05:30 PM   #1163
expert in tautology
bear's Avatar
George,
Your diagram shows explicit filter elements or intrinsic resistances and inductances?
A bit of this depends on exactly which, since serial filtering *might* yield vanishingly low noise and hum at the end of the chain.
_-_-bear
_-_-bear
Old 24th September 2012, 05:43 PM   #1164
PMA is offline PMA  Europe
PMA's Avatar
_-_-bear
I think yes. IMO the good audio circuit design should have
- very high speed, both wide bandwidth and very high slew rate
- very high immunity to RFI/HF demodulation and detection
- high High Frequency PSRR
- low distortion with no (or maximally suppressed) higher harmonics
- low noise
Old 24th September 2012, 06:24 PM   #1165
Joachim Gerhard's Avatar
Low crosstalk up to high frequencies is on my list too. Even a good potentiometer has enough parasitics to screw that up in the treble.
Old 24th September 2012, 06:36 PM   #1166
jan.didden's Avatar
George
Since you cvan't have all your loads directly at the psu (unless you give each stage its own psu) a good way is to determine the stage with lowest PSRR and put the psu closest to that. And, if you're serious, use remote sensing for the regulator at that stage.
jan
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Old 24th September 2012, 07:10 PM   #1167
forr is offline forr  France
forr's Avatar
Electronically speaking, everybody shall agree that crosstalk at high frequencies is an undesirable thing as it looks as a parasitic signal.
But for a good stereo rendition, it may not. Who does remember Edeko's articles in Electronics World ?
Old 24th September 2012, 07:14 PM   #1168
I know that phono cartridges with -20dB crosstalk can just sound fine. Some bleeding in the other channel may even enhance the perception of spaciousness. Schroeder has shown a circuit like that in the 70th and there have being processors from Carver, Bongiorno and others. I rather prefer that not be be a characteristic of the electronics.
Old 24th September 2012, 08:19 PM   #1169
Good stereo separation in the electronics is VERY IMPORTANT. Don't be fooled by phono cartridges Joachim.
Old 24th September 2012, 08:24 PM   #1170
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default More details intack with high isolation beteen channels-
In some old timey circuits there was a "blend" control to have you cover that "hole in the middle' with some mono. That helped when speakers were too far apart.
Short version -- If you mix/blend left and right towards mono you will find a lot of info gets cancelled out in the process. That is the effect of reducing channel seperation or isolation -- if you want all the details in tack, you design circuits with as little 'blend' as possible. - RNMarsh
Discrete OPAMP audio-gd Vendor's Bazaar 27 20th September 2012 04:02 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2013 diyAudio
