Salas hotrodded blue DCB1 build
Old 25th April 2012, 03:34 PM   #1911
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by schubert View Post
Then otherwise a 100VA R-core and a 100VA toroid should be pretty indistinguishable in terms of sound? That's my impression.
Subjectively to my ears the result is calmer and softer with R-Core. Don't know if it is the discrete bobbins, the shield, or the lower capacitance for line noise coupling from primary to secondary.
Old 25th April 2012, 03:38 PM   #1912
Salas's Avatar
Originally Posted by AndrewT View Post
If the second follows from the first, then surely there must be some audible benefit?
20dB (1/100th part) is a mighty big reduction in mains harmonics.
MC phono is a special needy case and there it is a must if in same box. Line or power level can be made quiet enough with no positioning and wiring mistakes when using EI or toroid. Still you may remember Roender recommending R-Core for close proximity boxing up with his folded cascode amp. I think you got one of those?
Old 25th April 2012, 03:40 PM   #1913
But that is not addressing the claim
Good for minimal magnetic field
regards Andrew T.
Old 25th April 2012, 03:43 PM   #1914
Salas's Avatar
What claim?
Old 25th April 2012, 03:49 PM   #1915
Salas's Avatar
P.S.
just found some nice description of the R-Core design and traits here by just googling:
Products - Custom Magnetics, Inc.
Old 25th April 2012, 03:50 PM   #1916
That claim in post1904 and followed up by
20dB lower harmonic noise when exchanging a toroid with an R-Core
regards Andrew T.
Old 25th April 2012, 03:53 PM   #1917
Salas's Avatar
I don't think its a claim to say I found the R-Core emitting lower field than usual transformers, its designed for that.
Old 25th April 2012, 03:57 PM   #1918
You are supporting the claim by re-expressing it.
Have you previously posted elsewhere your experimental method and/or details?
regards Andrew T.
Old 25th April 2012, 03:58 PM   #1919
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
My B1 is inaudibly quiet with a standard toroidal transformer.
With a Salas Shunt Reg, that gets rid of almost all residual noise.
Is it realy necessary to go the added expense for inaudible gain.
Old 25th April 2012, 04:04 PM   #1920
Salas's Avatar
As I told you no, I haven't saved and posted before and after FFTs but I think that I had mentioned enough times in the phono thread that I use R-Core in solo MC boxes after I had found toroid unusable for hum and buzz unless separately boxed. I have no reason to pay bank transfer and shipping for R-Core from France if a locally made and instantly available toroid could cut it.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 06:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 04:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
