Re: Went looking in HK
By now you're probably home already. But, just in case you're going back, since Manila is not that far away, as compared to NYC.
You were strolling in the ritzy touristic area. Those audio stores are not the places to look for exotic things like Zhaolus. Sonys, Aiwas, yes, but not the "unheard of" brands among the non-fi folks.
The high-end stoers are not there, but rather in Shum Shui Po (Ap Liu St., Eddie Wu's address?). So, you'd have to take the train to perhaps the Cheung Sha Wan station area. You'll find many such stores. There are also audio stores on I think Sai Yeung Choi St., at the beginning (south end), mostly housed in a couple of high risers.
I used to live in HK, that's how I know. I was last in HK 3 years ago. Since HK transforms itself every second..... But.... Ap Liu St. area still has the audio stores you and I would go, not Tsim Sha Tsui.
I am new as a poster here, so I can't send PMs out. I am looking to mod a Zhaolu 2.5c that I "WILL" be getting soon. Nobody has it in stock here in the U.S. I would hope to be asking the experts in this thread about a couple of simple mods, like inserting the LM 4562. I'm not a technically sophisticated person. I would need a road map to find the spot to do the replacement. I've gotten some pictures already, but, I'm sure I will have questions.
Thanks in advance.
fallen said:Walked around Shim Sha Pui, saw a lot of audio stores, but amazingly didn't see any Zhaolu DACs.
I was walking in that area near dragon center, where the street stalls were set up. Saw a lot of stores including wing shin i think. This was after xmas.
All sold out? or did I miss something? Only my second visit to hong kong. was still disoriented.
Thanks in advance.
Hi Guys,
Can somebody tell me what are the power connector (6 pin header) on the digital board connected to? This is a Digital board so one would expect to have only Vcc +5 and Gnd, but the connector is a 6 pin.
I am planning to move this board into a different case in which I have built a descrete output stage. So, I will have to build the supply neccessary to power the digital board.
The output connector I think is
L+
L-
Gnd
R+
R-
Right?
Thanks,
Dinesh
L+
L-
Gnd
R+
R-
Right?
Thanks,
Dinesh
Joined 2003
The easiest way to find out would be with a multimeter and visual inspection of the PCB traces. I'd have to take mine all apart to know which pin is which, but there's 5V analog and 5V digital supplies with separate grounds, and 2 lines trigger the relays (relay control circuit is on the power supply board).
The output connector you are correct, though I'm not positive of the polarity, but I don't think it really matters.
Dcibel,
Thanks for answering. I did not know there was a 5 V analog. I did measure, and 2 pins came up GND and 2 pins came up +5V and I though they were both the same 5V supply. I did not realize the 2 5V supplies are 2 separate supplies. I could not detect any voltage on 2 pins.
Regards,
Dinesh
Regards,
Dinesh
Any chance of seeing some close-up images of your finished boards? Would particularly like to see what you cut on the grounds. Sounds like a full-house job!
DcibeL said:I got a little exited when I got home with my parts order, so I went to town replacing parts last night. I should be able to give these changes a listed tonight, but in the meantime here's a bit on information on what I've done.
Power supply:
-lots of changes to the grounding arrangement. If I remember correctly the digital ground could only complete the circuit by passing through the chassis. I separated the chassis ground completely, and separated the ground plane at the two big caps. From each power supply circuit (two 5V supplies and analog +/- 15V supply) the ground has a single path back to the transformer through a wire.
-Chassis is connected to earth ground
-replaced all electrolytic caps. Smaller caps were replaced with Nichicon PW series 50V caps. The two big caps are Nichicon PW 35V. The two big 2200uF ELNA caps were replaced with Panasonic FM series 25V. Noticed that the G-Luxon cap installed on the board was a 25V cap with 25.5V on it. Yikes! I purchased a 25V Panasonic FM to replace it, but I put one of the ELNA 3300uF 35V caps here instead.
-replaced rectifier diodes with fast recovery schottkey type.
Digital board:
-removed all connections from ground to chassis.
-replaced 100uF tantalum caps on the analog 5V supply with 47uF Nichicon PW 50V caps.
Analog board:
-replaced 4 electrolytic caps in the supply with 2 Nichicon PW 50V caps.
-removed beads
-replaced op-amps with LM4562
-bypassed input coupling caps
-replaced the rest of the circuit with something similar to what Kevinkr designed. I added a bit to it to keep the transfer function close to the manufacturer's recommended filter. Resistors used for this are expensive Vishay CMF50 series, and caps are Panasonic ECQ-PZ (polypropelene).
-bypassed unneeded output buffer.
The only testing I've done so far is that I made sure the power supply still worked after all the track cutting I did to it.
Joined 2003
Oh, you don't really want to see that embarrassing sight, do you? I'm not even sure I can show where all the ground track cuts are, as I remember some of them were underneath parts...I can only recommend that you have a close look at the circuit, reverse engineer it a bit, and see what you can do with a scalpel, soldering iron, and some wire to improve it.
My main intention of modifying the Zhaolu was to improve the output filter, and also to replace all the electrolytic caps as the ones that were installed were not the correct voltage rating and so would not withstand the test of time. The extra work of changing the grounding arrangement was just extra work that I thought was a good idea to do "while I was in there".
I may have a look at the Zhaolu board over the weekend, and see if I can take some photos that can at least describe the changes made to the power supply board.
DcibeL said:Oh, you don't really want to see that embarrassing sight, do you? I'm not even sure I can show where all the ground track cuts are, as I remember some of them were underneath parts...I can only recommend that you have a close look at the circuit, reverse engineer it a bit, and see what you can do with a scalpel, soldering iron, and some wire to improve it.
All understood. Power supply board pic would be hugely appreciated!
Joined 2003
DcibeL said:Didn't get to it this weekend, had to deal with tremendous water damage to my newly purchased Condo....
Hope things dried out OK.
Hi I got a zhaolu D3.
It sound great only thing is when I sit an the couch with my computer and there is a static discharche. The Dac produces high frequent digital output and blew two times a tube of my amp. Also when I switch the amp on off or the cd player on of.
I did connect after that a net filter and connected the digital ground to earth. But nothing helps??
Does any one know what to do about that? Thanks Helmuth.
Does any one have a drawing of the circuit of the D3?
deuginthesky said:Just shut down the DAC in last.
That is not a satisfying solution. There must still be a bug in the hardware where the digital circuit loses control and oscillates.
I agree. Are you using a true digital cable or just an interconnect? Does it also occur over the optical link from the transport? What are you using as a transport (a DVD player, a CD player, a computer)?
More info is needed on how you are connecting this to diagnose the problem.
BobM said:I agree. Are you using a true digital cable or just an interconnect? Does it also occur over the optical link from the transport? What are you using as a transport (a DVD player, a CD player, a computer)?
The Marants cd17mk2 is connected coax, the philips dvd coax, the tv optical.
The fault occurs when I got a static discharge to my laptop how is connected to the same net voltage.
There is no direct connection to the DAC other then the net voltage, with the laptop. It even seems to me there is a radio frequent pulse from the static discharge how makes the DAC oscillate.
The dac even reacts to switching on the light, with the net filter this is solved till now.
It can stand switching on the CD player but switching it of makes the dac to go into the oscillation state.
My profession is electronics and I work on a R&D of a firm how makes switching power supply's and lamp drivers from 15W to 34kW.
What I need is the solution to the problem, or a a schematic of the DAC to find the solution.
Regards Helmuth
Regards Helmuth
Greetings,
I also have a D3 and is having the same problem as you. I didn't know what problem it was until I saw your post.
For my case, things start to go wrong when either 1) A computer PSU from another room is switched on, 2) I switch on the DAC followed by the amp, 3) I plug in the USB harddisk (???)
And for my case it's not a high frequency digital output although it appears to be so, but it's actually a severely clipped and super-loud audio signal. I managed to find out because most of the time I set the source volume at near zero so I can max the amp. It will just get veeeeeeeery loud and clip if I increase the volume from the source by a bit.
Currently looking for ways to solve the problems. I've tried 1) Changing the PSU of the other computers (didn't help), 2) Changing sound cards (helped a bit), 3) Ungrounding the DAC (didn't help), 4) Reversing the polarity of the DAC (didn't help).
You mentioned a net filter, what's that?
wwenze said:
Greetings,
I work at development department of a firm how develops and produces lamp drivers every unit needs a filter to prevent high frequent noise spread on the supply voltage.
They are also sold in this form. To place in series with the supply voltage. Sold in different current ratings. 1 ampere is enough in this case.
Recent the problem became worse with my Zhaolu DAC.
Cause I had placed the DAC above the tube amp transformers.
The magnetic interference of the transformers was the cause playing loud or switching things trigged the DAC to oscillate.
So try place the DAC free from other electronics and see if it improves the stability. Try to shield it with a good earth shielding.
Because of this I think it will be use full to clean al screw holes from paint so the bottom and cap of case makes a good contact with earth to shield the electronics of the From from magnetic interference.
Regards Helmuth
You could also effectively implement a "star ground" by running a wire from each screw to a central spot. Ideally you would need to isolate the chassis ground plane for this to be more efficient, but you could probably get away with it even with just running the wires.
There is no central ground location that connects to the ground pin on the incoming AC line, so you will need to connect the ground on the AC to your start ground point as well.
Bob
Bob
Lucky, I happen to have one of those lying around, and enough diy skills to build one should the need arise, but I try not to play with mains voltage.
I'll remove the amp from the top of the DAC and see if it helps.
Update: Ok, what I did - Removed the amp to a faraway place, added 2 more ferrite choke rings to the DAC's power cord, used Zhaolu D2.5 as a shield by placing it on top and grounded,
Switch the power of the computer in another room, still *prszzzzzstuztstuztstzust*
Maybe for my case it's just plain bad mains power quality.
- Digital Line Level
- Zhaolu DAC - a good value DAC?
