Hey, they often areBut i will say that she is a very beautiful Norwegian girl.
Greetings from Norway. Best of luck with your new modules.
Thanks Lars.
Remember to log out of all the forums you have joined. Otherwise your better half (girlfriend) may cause problems.
Since you probably understand some Norwegian you may have fun reading this thread:
http://www.hifisentralen.no/cgi/yabb/YaBB.cgi/YaBB.cgi?board=hifi1;action=display;num=1123171839
Lars Clausen said:
Elso: Sure, but still i will not show you my prey .. he he
Prey???? Here she is from Nigeria!
Lars, If your girlfriend still allows you to read these forums (hahaha.....) just letting you know I've received the T-networks from you last week.
I'm still waiting on other parts, but the initial impression is an interesting one none the less, they're only half the size of the Cerafines, for the exact same 63V 10 000uF rating.
I should have more answers in the near future.
Thanks,
Chris
Thanks,
Chris
SMPS
Hello Alab, I've seen your posts before and I had a look at your website. The problem is; the website gives no substantial information on the supplies, e.g. regarding continuous power vs peakpower, topology (according to the website all your supplies, from 300W to 4.2kW are build from the same principal half bridge schematic and all have the same PCB and components) etc.
Furthermore it is not clear in what currency the price is. Is it Thai or dollar or what?
I read somewhere some comments on them from a DIY member (Eva) that did not encourage me specificaly.
Anyway, could you give us some more information (in understandable English please )
Regards, JZ
alabpro said:Hi all
I think switching power supply work for class d amp
pls. www.alab-pro.com for switching powersupply
Regards, JZ
Re: SMPS
I recently found switching power supplies from MeanWell. Two single sources in sereis can be used to result in +/- power. It seems no modification is required becasue the - side and the ground are asolated.
Regards, JZ
Re: Re: SMPS
You can check spec switching power supply in Pl-series
The pl-series use switching power supply and continuous power and peakpower you can up +10%
the price is in usd. with out shipping
and supply test by continuous power 1khz.
mode MONO ( sp1000xx)
90-0-90 or 80-0-80 V
power out 350w/ch at 8 ohm or
power out 425w/ch at 4 ohm or
power out 700w/ch at 2 ohm or
power out 1000w/ch at 1.8 ohm
by www.alab-pro.com
Regards, JZ
by www.alab-pro.com
Re: Re: Re: SMPS
power out 425w/ch at 4 ohm or (10.3 amp at 4 ohm)
power out 700w/ch at 2 ohm or (18.2 amp at 2 ohm)
power out 1000w/ch at 1.8 ohm (23.5 amp at 1.8 ohm)
by www.alab-pro.com
power out 350w/ch at 8 ohm or (6.6 amp at 8 ohm)alabpro said:
HI Joep Zonnebloem
by www.alab-pro.com
by www.alab-pro.com
Re: Re: Re: SMPS
The PI series are amplifiers, how about power supplies? What is the switching frequency?
alabpro said:
HI Joep Zonnebloem
by www.alab-pro.com
Re: Re: Re: Re: SMPS
soongsc said:
The PI series are amplifiers, how about power supplies? What is the switching frequency? [/QUOTE
HI soongsc
Model PL2.4 use 99-67-0-67-99 Volt
Model PL3.0 use 117-67-0-67-117 Volt
Model PL3.6 use 134-82-0-82-134 Volt
Model PL4.2 use 145-82-0-82-145 Volt
the switching frequency = 96-110 khz
Alabpro,
I have send you an email, can you please respond?
Or send an email direct to me; info@hypex.nl
Thanks!
Regards,
Jan-Peter
Thanks!
Regards,
Jan-Peter
Sp-xxxx
Hi Alab,
Well that is some more information at least, thanks. But it is like you are not very happy to give extensive info on your products (or you don't know what information is relevant for DIY; in that case I could give you some hints).
But 140 dollar is a proper price, I think, so I could give it a try. Still some more questions that are important for a class d DIY:
- what are the dimensions (!)
- what kind of output filter do the supplies have (can I easily add extra capacitance?)
I think I would go for the 2400, which would give me over 1kW in 4Ohm, if I can extrapolize your specifications on the 1000 model (can I?).
The MeanWell supplies have a nice website with ample specifications (.pdf's), but for my needs (+70V 0V -70V) they are not suitable.
Best regards, JZ
Hi Alab,
Best regards, JZ
Re: Sp-xxxx
If you don't find anything else, I think you could actually put them in series to get the voltage you need. I got two 48V ones to get +/-48V, and I called them about my intent, they see no problem.
Best regards, JZ
Jan-Peter said:Alabpro,
Thanks!
Regards,
Jan-Peter
hi Jan-Peter
my email keaw2@truemail.co.th
- Class D
- ZAPpulse 2.3SE vs. 700XE
