I've decided to use a Jim's audio board instead of buying the yuanjing pre-built one. It's going together well but I'm missing a few parts like the LM3886 and the 8.5mm pitch terminal blocks for the speakers and transformer which I can not seem to find anywhere.
Is this a suitable transformer for this amp?
Buy Toroid Transformers Toroidal transformer,225VA 2x30V o/p Nuvotem 0225P1-2-030 online from RS for next day delivery.
picture of amp here.
Just for you to know, I did buy this kit, based on Mauro Penasa's design, in its last parts version, and I have been using it for seven months now.
Classic lines LM3886 dual-channel +LM318 AMP/ DIY | eBay
I must say I was worried, both about the parts quality and mainly about the audio quality. Audio quality is excellent, so I would recommend it as a real Mauro Penasa clone.
Hi, ive completed the amp and it sounds very good!! no complains at all really. The bass is a little flat and dull but I'm only using a 80 VA 2 x 25 transformer with 4700uf filter caps so that could be why. But I'm only using my test speaker not my main ones that have more bass but don't trust the amp enough to use them without further testing!!
The amp is also very quiet when I turn the input all the way up only very minor hiss and hum can be herd.
Looks kinda funny with that huge heatsink but that is for only for testing purposes. My drill tap bit broke when trying to tap the second hole that why there is only one screw in the there.
I'm going to buy a larger transformer maybe a 320VA I think it will benefit from it, and may upgrade the filter caps to 10,000uf . Ive already tried replacing one of the NE5532 with the Burr-brown op-amp from my cmoy project. But its too soon to see if it makes a different. But ive only listened to it at very low volumes as its late at night. My first impression is that it has.
Is it possible to see a schematic for that amp? Perhaps we could hint why bass is flat and dull.
I do remember when we carried out some tests with a friend with two 3886 amps, one with 4700uF on each leg in the supply and the other with 1000uF. The one with less capacitance had better bass detailing than the larger one. The highs and mids were also better. The other one seemed to have more bass.
The original gainclone seemed to need a zobel if you used larger capacitors in order to get more bass and still have a better bass, but that also seemed a matter of taste.
Maybe that's what's happening on your case.
It might also be a question of letting the parts burn in.
Here's the schematic for the amp. You don't think the lack of bass is due to the small power supply used? I have some Nichicon 10000uf caps I got the other day so I could try them to maybe increase the bass. The highs and mids on the amp at normal listening volumes are too much. I could not listen to it that long.
From what I see, there shouldn't be any major problem with the amp.
You won't get more bass quality just by adding more capacitors. You already seem to have 10000uF/63v on the supply, though the schematic does not show the terminals for the power amp, which should be before the 22K resistors. Can you check on that?
Some critical points, that might affect audio quality:
1) Signal path capacitors. Those 2.2uF caps should be film types, though I think those are the large Russian types on your board, right?
2) Unnecessary buffer. The second stage of the preamp is unnecessary and should be bypassed, with a wire or using the 1K resistor to go from pin 1 to pin 7.
3) Feedback capacitors. The NFB caps on the 5532 (10uF/25v) and 3886 (22uF/50v) should be good quality types.
4) LP caps. Check that those 100pF caps in parallel with 22K are good quality types. Polystyrene or silver mica.
Look for CFM suggestions for using a zobel on the supply.
Thanks for the reply.
It seems the problem was with the crappy speaker I was using for testing, I've connected my good ones and now the amp has plenty of bass and the mids and highs have settled down to a nice level.
It's impressive how cheap this thing is how much power and sound quality it can produce. I want to build another without the buffer with a better power supply more capacitance and bigger transformer!!
- Chip Amps
- "Yuanjing" Gainclone 3886 - eBay amazing value ?
