I figure I'll post as I'm probably one of the higher ranking cluttermonkeys...
My room/work area, as you can see I have no problem with space as long as I can keep stacking...
Notice my ancient oscilloscope. Dated around '67... Other side...
Top of my station...
The pile in the middle of the room...
As you can see, I have a pet turtle. Its name is Squeegie. Last one, this is my A/V system.
I clearly realize that I have a box of drawers by my bed, but this is not illegal because they are not even in use! HAHAHA!
At any rate, I have the empty soda cans unwashed plates you asked for, Poobah...
- keantoken
- keantoken
Nice.
I suppose if you cleaned up, you would not be able to find anything, correct ?
Does this statement apply to you ?
.... "I thrive in squalor."
I see a box for a "4-in-1 Handy Trolly".
That is an item that declares itself as obsolete in your case, and exudes "purposelessness".
=FB=
=FB=
dnsey said:What a fantastic breadboard!
Did you make it yourself?
thank you... yes, i built it with a friend, we designed it together and built two; that is ver. 1 - i'm in the process of building ver. 2, it uses a PCB for the tube sockets and adds a third row of barrier strips below the tubes, along with a section along the upper right corner for tube rectifiers and can caps...
keantoken said:Jesus! What kind of camera are you using?
sony 7.2mpix - ziess lens. forgot model #
Nice setup, BTW. Earns envy points +5.
thank you...
- keantoken
dfdye said:I just noticed the ferric chloride next to the toothbrush. I KNOW that toothbrush is NOT for brushing teeth, but the thought sort of gave me the heebejeebes for a second there! Still, I wonder what it would do to braces. . . .
make them nice and shiny?
You should have seen my shop before I cleaned it...
http://img507.imageshack.us/img507/3470/0000008tx5.jpg
keantoken said:
The way I see it, if I can build a fly zapper in less time than it takes to clean my room, I'll go for it!
- keantoken
Other DIY projects we might consider......
DIY Vacuum
DIY Trash Can
DIY Shelf Unit
DIY Maid
__________
(edit....DIY "really hot" Maid )
=RR=
AR2 said:Man, too much Dr.Peper.
Nothing goes better with rum than warmed up Dr. Pepper and a lemon slice.
poobah said:
That sounds good... while you're on the subject... Crown Royal and Vernor's make a nice, unexpected delight.
Every time I go to Cleveland I get a couple cases of Vernor's. Same with the Great Lakes Brewery beer. They don't have Vernor's in NJ.
I thought Crown Royal went best with ice, or maybe with a little sweet vermouth, a dash of bitters and a cherry.
- General Interest
- Everything Else
- Who has the dirtiest office or lab?
