no problem godzilla...............
Detail will be the issue.
Smaller, lighter, stiffer cones keep the detail high but at the expense of no bass.
I was even looking at the 5.25" carbon-fiber audax drivers (used in the von schweikert VR6. High detail and clarity comparable to electrostats...... that says a lot to me.
http://images.google.com/imgres?img...q=schweikert%22+%2B%22vr+6%22&um=1&hl=en&sa=N
I liked my b20 actively crossed at 5khz @24db LR to a 1038a piezo (with 60ohm in series with piezo). Screw power response.
I'd imagine the 2 x audax should kick its butt. But $90 U.S. each.
Still cheaper than a cheap lowther !!!!!!!!!!!!!
Norman
Norman
Ciare again
Here I go again, but I just spotted 2 interesting drivers more, in Ciare home-catalogue HX160 and HX201
Sp=95/96 db
Qts=0,42/0,47
Vas=16/44 l
Fs=70/53 Hz
Xmax=1,7mm
They dont have whizzer cone, yet to15KHz they go,with less beaming,so Ciare claims. HX201 for half chang maybe?
Sp=95/96 db
Qts=0,42/0,47
Vas=16/44 l
Fs=70/53 Hz
Xmax=1,7mm
