What have you built lately?
Testing new power supply. No hum at all audible when all faders are up on +10 dB, headphone amp all the way up. Only noises from microphone preamps. Oscilloscope on 5mV/div shows no ripples at all.
I am satisfied. Time to mount the PS. New holes have to be drilled, it is thicker now, so old holes do not fit. However, one wire had to be soldered outside, I forgot about +42V anode power for UV meters.
Wow, a lot going on in there^. Cool that it’s working nicely with any unexpected hiccups.
I have been entertaining myself hotrodding an old bgw 250 amplifier, sounds nice now with better decoupling, and ditching the funky caps in the signal path for better quality parts.
Joined 2000
Some interesting projects here.
Just working on a couple of things.
Amp cases for MoFo Power Follower.
Was making a prototype for a balanced power unit.
Decided to not pursue the venture.
Just remembered I need a high gain preamp for the MoFo.
Red boards in the background are for a BA-3 frontend.
Wooden sleeve for a vintage Fisher 202T tuner-pre rescued from an old console.
Tight fit - not a lot of overlap on the front panel to achieve any fancy bevel detailing, so just went simple. QC Sapele veneer on BB ply.
and yes, I definitely subscribe to the "tidy workbench is a sure sign of OCD" philosophy - although whenever I do clean up, I find a couple of extra Olfa knives and tape measures. ;)
Got a bass guitar, so I built a little 45W 4x6". Two are in a small 4th order bandpass, isobaric, and two provide the mids. Sounds quite nice. I used bits and pieces I already had. I only put together a small 10x gain preamp buffer extra. :)
