What circuit and tube to be used
HI CK
Please help me by providing the specifications for the transformer. Also Manufacturers name, model number. I need more information to get started. With this information provided you are much more likely to get suggestions. Also good luck with the project.
Bob
Thanks to your questions.
Sorry, they are second hand o/p dismantle from PWR amp also they are not a commercial product. Seems a DIY thing made in China / Taiwan with an external iron box enclosed.
I want to make a single-ended PWD amp around 10W.
There is some description
Primary :
Red color wire connected to transformer with "B" marking
Yellow wire connected to transformer with "P" marking
Transformer body :
Have string "LM-1K-25F" & Zp : 1Kohm
Secondary :
Have 4 wire marked as 0 / 4 / 8 / 16 ohm
Hi!
If You'l build SE aprox. 8-10 wts, You can use russian 6S41S - Ri=300 ohm /6С41С/ with Ia= 100-120 ma, and wire diameter primary coil must be aprox. 0.3 mm!!....Or
2 parallel 6S19P - Ri=150 ohm /6С19П/, with Ia=60 ma each,
or 2 par. ED8000 - http://www.tubedepot.com/nos-ed8000.html
Preamp. EF861, E180F. If You interest, I can give You a schematic - 6S41S & EF861 !
But first, You must measure wire diameter!!
However, I had already bought this pair of output transformer. Not sure they suit for your power amp circuit ?
This is there descriprtion
Primary :
Transformer body :
Secondary :
Can anyone one tell me 1k o/p transformer for which type of tube power amp design ?
Possibly a Circlotron. I have used 1k and 1k2 OPT with these.
