Thanks to your questions.
Sorry, they are second hand o/p dismantle from PWR amp also they are not a commercial product. Seems a DIY thing made in China / Taiwan with an external iron box enclosed.
I want to make a single-ended PWD amp around 10W.
There is some description
Primary :
Red color wire connected to transformer with "B" marking
Yellow wire connected to transformer with "P" marking
Transformer body :
Have string "LM-1K-25F" & Zp : 1Kohm
Secondary :
Have 4 wire marked as 0 / 4 / 8 / 16 ohm
Primary :
Transformer body :
Secondary :
Hi!
If You'l build SE aprox. 8-10 wts, You can use russian 6S41S - Ri=300 ohm /6С41С/ with Ia= 100-120 ma, and wire diameter primary coil must be aprox. 0.3 mm!!....Or
2 parallel 6S19P - Ri=150 ohm /6С19П/, with Ia=60 ma each,
or 2 par. ED8000 - http://www.tubedepot.com/nos-ed8000.html
Preamp. EF861, E180F. If You interest, I can give You a schematic - 6S41S & EF861 !
But first, You must measure wire diameter!!
However, I had already bought this pair of output transformer. Not sure they suit for your power amp circuit ?
This is there descriprtion
Primary :
Transformer body :
Secondary :
Primary :
Transformer body :
Secondary :
Can anyone one tell me 1k o/p transformer for which type of tube power amp design ?
Possibly a Circlotron. I have used 1k and 1k2 OPT with these.
almost sounds like X-mas )) my guess is that's some German pieceIt's "guess the transformer" time again!!!
This is exciting!!!
- Tubes / Valves
- What circuit and tube to be used
