Dear Lazy Cat if its possible, not to late i will take 1 set for stereo
Done, thanks
The 10uF MKT cap with 15 mm lead spacing seems to be this one: MKT1820610065,
data sheet: http://www.vishay.com/docs/26011/mkt1820.pdf
15-mm seems not to be common spec in that value, can someone confirm that? In the US, available from Newark @$3.15 ea, plus $20 freight.
Yes, there will be 250 sets in this GB, so at this time there are still some 30 PCB sets available.
Ok,
so count me for 2 boards !
Connexelectronic
Use one for the two channels (that i prefer).
hm
100EUR,
100$,
I have lots of smps computer power supplies, what do you think, adding some windings to the transformers will give higher voltages... they are shielded and ventilated... are they worth reworking them for ie +-35Vdc?
It is also possible to use Epcos MKT 10uF/63V with 15mm spacing.
Unless I am mistaken, computer power supplies (PC supplies) are like a different animal. More than transformer changes would be required to make one work.hm
100EUR,
100$,
The SMPS800 (800W) from Connexelectronic seems like overkill, even if you derate it 50%. Not sure the logic behind specifying a regulated supply, but there are probably some inexpensive linear regulated power supply designs that you can build for very little $$ (or buy online). Might be interesting to try a cheap linear regulated supply b/f spending 100 Euro if on a budget.
Found it now, thanksIt is also possible to use Epcos MKT 10uF/63V with 15mm spacing.
Hi guys
New listenings made recently in Germany.
Pictures as follows
- Zu Soul Supreme
- Zu Soul Supreme
- Zu Druid
Comment of the owner was that VSSA perfectly matches with Zu, live music.
Pictures as follows
- Zu Soul Supreme
- Zu Soul Supreme
- Zu Druid
dear LC please stop teasing
As you can see I try to find the most musical speakers possible which are still normally sized. My Trios are just too big for presentations.
SWISSsonor BACH12 were also connected, even more bass, not so coherent, WAF unacceptable and just too big.
Among all three speakers Zu Soul Supreme was the best, most coherent, vivid and super dynamic, listening the vinyls was one of the best sounds I ever encountered.
I hope VSSA will play well with my Sansui 96dB efficient speakers...
if not - another purchasing...
Is there any (reasonably priced) Zu Union around to try it with VSSA?
I recommend Zu Soul Supreme. There are also cheaper Zu models but this one has the same tweeter as their top Dominance model and it is one of the best.
GB Order Confirmation
Hi dear GB members
VSSA PCB set includes:
- VSSA PCB with preassembled SMD parts and faston spade connectors
- ALF08NP16V5, KSA1381, KSC3503, BC550C, BC560C transistors
- two polyamide spacers for KSA/KCS
- kapton insulator washer for ALF
Price: 38 EUR/set
GB members from the list below, please check if ordered quantities are correct.
Please send your exact address for shipment delivery and also your e-mail address to my e-mail, so I can send you the quotation with all details about the payment and shipment costs:
[B]esl@siol.net[/B]
Current GB members list:
Joachim Gerhard 2 PCB set
AKN 2 PCB set
Idefixes 2 PCB set
kimon 2 PCB set
brianco 2 PCB set
Dane 6 PCB set
MKHunt 2 PCB set
Cambe 2 PCB set
boyet0173 2 PCB set
tom42107 2 PCB set
presbel 2 PCB set
meltman 2 PCB set
gannaji 2 PCB set
dodo 2 PCB set
coolet 2 PCB set
jj506 2 PCB set
vgeorge 2 PCB set
touchdown 2 PCB set
wponline 2 PCB set
Luke 4 PCB set
cvtaudio 10 PCB set
Renio 2 PCB set
maillard 2 PCB set
PauloPT 2 PCB set
hcbonfim 2 PCB set
gusto142 4 PCB set
PinkPink 2 PCB set
bressix 2 PCB set
nico2k3 2 PCB set
routhun 2 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
Murdoc 2 PCB set
regal 2 PCB set
AUSTINP 2 PCB set
kroyin 2 PCB set
fredlock 2 PCB set
mikvous 2 PCB set
myfi 2 PCB set
FelixG 4 PCB set
ichiban 2 PCB set
padamiecki 2 PCB set (no ALF)
gogu 2 PCB set
joshvi 2 PCB set
philippeleite 2 PCB set
mefistofelez 4 PCB set
DavorXXL 6 PCB set
sakdi 2 PCB st
buzzforb 2 PCB set
acqu27 2 PCB set
siberia 2 PCB set
baswamin 2 PCB set
miksi 4 PCB set
chunek 4 PCB set
raysimmons 2 PCB set
johnkrammer 2 PCB set
jony 2 PCB set
sng001 2 PCB set
atupi 2 PCB set
analog_sa 2 PCB set
davidhoang 4 PCB set
Malvin 2 PCB set
vitalica 2 PCB set
Andrewc556 2 PCB set
88bruce 2 PCB set
jkuetemann 2 PCB set
RAYSIMMONS 2 PCB set
Odysseas 2 PCB set
yassud 2 PCB set
Junie 2 PCB set
ivanlukic 2 PCB set
gazzagazza 2 PCB set
Telstar 2 PCB set
Rick G 2 PCB set
Maxlorenz 2 PCB set
electromf 4 PCB set
Pinnocchio 2 PCB set
PMI 2 PCB set
BYRTT 4 PCB set
MeTarzan 2 PCB set
RNMarsh 2 PCB set
tinitus 2 PCB set
AVWERK 2 PCB set
OZAM 2 PCB set
pronk 2 PCB set
mad_z 2 PCB set
wewe 2 PCB set
androuski 2 PCB set
Hi dear GB members
Price: 38 EUR/set
[B]esl@siol.net[/B]
AKN 2 PCB set
Idefixes 2 PCB set
kimon 2 PCB set
brianco 2 PCB set
Dane 6 PCB set
MKHunt 2 PCB set
Cambe 2 PCB set
boyet0173 2 PCB set
tom42107 2 PCB set
presbel 2 PCB set
meltman 2 PCB set
gannaji 2 PCB set
dodo 2 PCB set
coolet 2 PCB set
jj506 2 PCB set
vgeorge 2 PCB set
touchdown 2 PCB set
wponline 2 PCB set
Luke 4 PCB set
cvtaudio 10 PCB set
Renio 2 PCB set
maillard 2 PCB set
PauloPT 2 PCB set
hcbonfim 2 PCB set
gusto142 4 PCB set
PinkPink 2 PCB set
bressix 2 PCB set
nico2k3 2 PCB set
routhun 2 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
Murdoc 2 PCB set
regal 2 PCB set
AUSTINP 2 PCB set
kroyin 2 PCB set
fredlock 2 PCB set
mikvous 2 PCB set
myfi 2 PCB set
FelixG 4 PCB set
ichiban 2 PCB set
gogu 2 PCB set
joshvi 2 PCB set
DavorXXL 6 PCB set
sakdi 2 PCB st
buzzforb 2 PCB set
acqu27 2 PCB set
siberia 2 PCB set
baswamin 2 PCB set
miksi 4 PCB set
chunek 4 PCB set
jony 2 PCB set
sng001 2 PCB set
atupi 2 PCB set
analog_sa 2 PCB set
Malvin 2 PCB set
vitalica 2 PCB set
88bruce 2 PCB set
Odysseas 2 PCB set
yassud 2 PCB set
Junie 2 PCB set
ivanlukic 2 PCB set
Telstar 2 PCB set
Rick G 2 PCB set
Maxlorenz 2 PCB set
electromf 4 PCB set
PMI 2 PCB set
BYRTT 4 PCB set
MeTarzan 2 PCB set
RNMarsh 2 PCB set
tinitus 2 PCB set
AVWERK 2 PCB set
OZAM 2 PCB set
pronk 2 PCB set
mad_z 2 PCB set
wewe 2 PCB set
androuski 2 PCB set
LC,
My details have been sent. I'd like to publicly thank you for all the extra effort you have put forward in organizing this group buy. I have no idea how much time and effort doing so has been involved but I'm sure that it will be worth it in the end.
Looking forward to this build. Thank you!
Jason
Jason
These group buys must be an enormous effort (I got tired just reading the list) which, summed to the work of building and testing amps, plus sharing the knowledge and expertise here, really must demand a lot of energy and enthousiasm from LC...so I don't consider you a lazy cat but a work-o-holic cat
I'm sure we all thank you, dear, from the bottom of our hearts.
Sincerelly yours,
M.
Sincerelly yours,
M.
- Vendor's Bazaar
- VSSA Lateral MosFet Amplifier
