Did your 16 YO buddies get a bandpass sub? That is one where the speaker is totally inside the cabinet (usually viewable under plexiglass) with some ports to vent the noise outside.
If this is the case I would imagine that they have NO crossover installed and your hearing mids bleed through the ports.
burnedfingers said:In serious audio the subwoofer response will be in the 20-80 HZ region. No subwoofer system worth its weight will be above 80HZ.
It isn't done in good theatre systems or in commercial systems.
I know because I do this for a living.
It sounds like the car stereo buffs got just what they paid for from the typical car stereo shop. They seem to associate the term bass with anything up to and including 250hz or higher. If there is a passive (inductor) installed it is of the wrong value. Keep in mind this will roll off the frequency at 6db per oct where as a good electronic crossover will roll off at 24db per oct or higher.
The fact is this.... most typical car installations are done by the uneducated self taught wanabee's.
When a professional job is done the result will be totally different but then again I personally see absolutely no need for car stereo in the first place and feel it should be totally outlawed.
I don't understand. The REL Studio III, arguably one of the best subs available (it better be at $8000) and has a response to 100Hz. Dynaudio's SUB 500 goes at high as 250Hz. Many, many more high end subs have frequency responses above 80Hz. Why would you make such a statement when it is blatently not true?
So far I don't see any proof as to me being wrong. I suggest you find some information on professional installation that includes frequency response.
Just because a certain company makes a product that cost XXXX amount and the public is stupid enought to purchase it doesn't make it correct or state of the art.
Responce to 100HZ hummm. Does this mean that its crossed at 100HZ? Does this mean that its crossed over below 80HZ at say 24DB per oct and still has information left at 100HZ? I don't think you have a clue here and based on the information here there is nothing to go by. I suggest some nice graphs of frequency response.
I suggest you dig up some hard information here or be happy with your little "Cube" systems with response up in the 200HZ realm.
1st: There is not much difference between 80 Hz and 100 Hz (approx 4 semi-tones) at all.
The REL subs have an adjustable crossover (i.e. lowpass) so they can be crossed over at 80 Hz as well or even much lower, depending on the mains.
The ubiquitous 80 Hz derive from some movie-industry standards.
2nd: It is absolutely impossible that there are NO voices coming out of a sub, given that our hearing has a dynamic range of 120 dB and most sub crossovers have a steepness of 24 dB/octave.
When the sub is well integrated however we don't PERCEIVE any vocals coming from it due to masking and the Haas effect.
If it has to be crossed over at only 6 dB/Octave the quality requirements for the driver(s) and amplifier are much higher than for those using steeper crossovers.
Charles
Charles
burnedfingers said:Quote:
To be honest, with your attitude, you are not worthy of a response. You think you know it all so it's fruitless discussing it with you.
Banned
Joined 2002
OUIE!!!!
Those kids are crazy, part II
What about it?
You cross it as you want, it's your sub.
Very likely.
Btw, the variable filter is usually not 24db/oct.
You would need a 4-gang pot to do that.
It's more like 12db/oct, with another fixed 2nd order filter just above the end of the scale (150~200Hz) .
I have found out by myself that this works very well, really. I use the variable filter set at 50~55Hz.
Now, listening to voices coming out of the sub with the main speakers connected and listening to music?
Those kids are crazy.
That's not hi-fi, that's boombox territory.
burnedfingers said:Responce to 100HZ hummm.
What about it?
burnedfingers said:Does this mean that its crossed at 100HZ?
burnedfingers said:Does this mean that its crossed over below 80HZ at say 24DB per oct and still has information left at 100HZ?
Very likely.
on semantics alone burnedfingers is correct. Calling something a sub means that it is capable of ULF ? or that it is to be used for that only? Its tough to decipher what the marketing weasel was at on some of the things we read. If it goes over 100 and has a hard time working at 40 i go with the BLOSE and call it a woofer (bassModule) since its not allowed to be called a subwoofer.
Just because it will play above 80 hz doesnt mean thats its intended purpose.
Here are two expensive high end subwoofers that contradict what you say. There are more, but I do not have all night to copy and paste text. If you respond, please leave the attitude out and discuss this like adults.
Dynaudio SUB 500
Price: $2000
Frequency Response 18 - 250 Hz
Amplifier Power 250 W
Lowpass Flat/60/80/100 Hz (18dB/octave)
Phase adjustment 0°/90°/180°/270°
Woofer 12" (30 cm)
Weight 30,5 kg
Dimensions (W x H x D in mm) 360 x 378 x 568
Sub Utopia Be
Price: $6000
Drivers 16" W Woofer, 3" voice coil, multiferrites magnet
(18 x 3" magnets)
In room response (-6dB) 16Hz
Frequency response (+/- 3dB) 20Hz - 160Hz
Amplifier BASH® 1000Wrms
Line inputs LFE Direct on RCA
LFE Direct on XLR (balanced)
Stereo on RCA
Stereo on XLR (balanced)
Line outputs LFE Direct on XLR (balanced)
Active crossover Adjustable from 40 to 160Hz (18dB/octave)
IPhase Adjustable from 0 to 180°
Mode selector Auto/off/on
Dimensions (HxWxD) 19.7 x 20.9 x 24.9in
Net weight 52kg (114.6lbs)
Here are two expensive high end subwoofers that contradict what you say. There are more, but I do not have all night to copy and paste text. If you respond, please leave the attitude out and discuss this like adults. Sorry, I had to respond, I just couldn't help myself.
Dynaudio SUB 500
Price: $2000
Woofer 12" (30 cm)
Weight 30,5 kg
Sub Utopia Be
Price: $6000
(18 x 3" magnets)
Stereo on RCA
Just because two "High End" manufacturers list response in the mid bass region doesn't make any point as far as I am concerned.
What I am looking for is text to back up the fact that the subwoofer region is extended that far. You have shown me nothing so far.
Side note*
With respect to my attitude....I suggest you also take a good look at your own.
Side note*
http://www.pioneer-eur.com/eur/product_print.jsp?product_id=10485
We are both wrong....
I just found this Pioneer with subwoofer response from 30-2000HZ. Thus proving that anything is possible. No need for a high pass filter on the main speakers either. Just let everything blend and duplicate. No need to worry about placement either.
- Subwoofers
- vocals coming out of subs?
