Very expensive binding posts vs Direct soldering
Magura said:
If we are down to binding posts now, the cardas binding posts were offered at so low price that they beat pretty much anything else. I bought the long rhodium over silver binding posts through the group buy cause I realized that I would have a hard time making them cheaper myself. Magura:)
What was the price? And in what quantity?
Since you live in Germany, why don't get in contact with Ruhstrat?
Massive copper, weight > 400 g! They have smaller also....
For permanent connectors I used the copper foil (from inductors). I cut 1" strip in half, but for better current capabilities, one can fold it for double thicknes. That post accepts spades, bare wire, or if you want, you can make your own "spades" from the same foil and solder it to speaker cable wires
Peter
Looks good.Two things I would consider:
1.Copper is going to oxide with time.
2.I think it would be good to glue the steel nut in that bakelite bar instead of making a thread in it.A couple of loosenings and tightenings and screw will destroy the thread.
Bartek
