Valve Itch phono
Joined 2009
Thanks George too much numbers, 7.7 ohms 0,39uF 53kHz
Administrator
Joined 2004
I recommend 3A Schottky rectifiers minimum for the sort of load current you are likely to see. Also when you build the new one space them 5mm off the board.
If you are using one bridge to power each channel the peak current is probably several amps or more - even a Schottky might be dissipating more than a 1/2W and conventional silicon over 1W and will get very hot.
(All swag on my part, no calculations involved)
Don't use that board material! :D
