A 6V6 family tube was desired for the "finals". The 12AQ5 was settled on, for its low price. Any 6V6 family tube works with the parts values shown in the schematic.
The B- rail could have been quite a bit "shorter". What was settled on came (you guessed it) from cost considerations. The fact that the B- supply is technically nice is a bonus.
As for "fixed" bias versions of the basic topology, refer to Poindexter's "Musical Machine". Poinz was 1st with this style of 2 stage amp and MUCH was learned from his efforts. The "Musical Machine" is an all out, cost be damned, assault on performance. "El Cheapo" is a budget project that performs far better than the money spent suggests would happen. While inexpensive, the PSU is anything but cheap.
All the small components are available from Jim McShane, and the trafos and such can be ordered from online electronics vendors.) Jim's page for the El Cheapo is here:
http://pages.prodigy.net/jimmcshane/elcheapo.htm
Actually my page is www.mcshanedesign.net/elcheapo.htm, the old link Jeff posted is dead.
How many watts per channel does a stock El Cheapo put out (say, with Edcor transformers)?
~Ten, AFAIK.
jeff
Approx. 6 WPC for triode and 12 WPC for UL. Some variation will occur depending on B+ rail voltage and selected O/P "iron".
Dynaclone Z565s are the "Gold Standard" for O/P trafos, in an "El Cheapo". Edcor's CXPP25-MS-8K is certainly hefty enough for UL mode. Stick strictly to triode mode, when low cost guitar amp "iron" is used.
Sorry...
I didn't want to bring back to life an old thread but I had to ask: did someone build an El Cheapo "on steroids" ? With EL84m or 6P14P-ev , higher voltage, fixed bias and MOSFET buffer (ZVN0545A, FQPF2N80...) between LTP and OT ?
If this is the case, is the schematic very different from post 20?
Pierre
Pierre
Frankly my goal isn't the max power but getting a bit over 15WPC shouldn't be too difficult with two 6P14P-ev in push-pull. I'd like to use vintage irons from old amps like PACO SA-40, Pioneer SX-82 or Kenwood KW-70 (real mess under the hood!) I saw recently ( actually these amps are supposed to be fully functionnal at decent price). Maybe I'll make a move but I'm not ready right now to build the El Cheapo.
I've seen a pair of EL84Ms producing close to that at 420V. IMO hefty OP iron is always to be recommended, for best linearity and frequency response.Pierre, are you "looking" to squeeze 20 WPC out of the 7189 equivalents, as Sherwood did in their S5000? If so, you will need hefty O/P "iron" that can handle upwards of 35 W. The GNFB loop mandates that, in order to avoid core saturation. Edcor's CXPP50-8K is suitable.
The easy way is to DC couple the FET to the driving triode's plate and cap. couple the FET to the driven O/P tube. All that's needed here is the impedance transform, as positive grid current is not in the picture.
The tweaked RCA phono setup shows the way.
Look at the ZVN0545A datasheet. Make certain you stay well within the safe area of operation. The drain voltage is known. The gate is at the triode's anode potential. The source will set up a bit below the gate, but not enough to worry about. Size the source load resistor to keep dissipation within safe limits. 1.5 to 2 mA. of drain current usually works well.
Oh yes! it's similar to Powerdrive from Tubelab (FET source follower). I used a 2sk3564 at the time to build a 45 SE. My God! I'm not really a tech guy...
Eli, BTW I prefer to use something a bit "beefy" like FQPF2N60C (or equivalent) than ZVN0545A. Since I use 6P14P-EV, the voltage could go over 400V.
Thanks!
Thanks!
- Tubes / Valves
- up-to-date El Cheapo schematic
