DaveM said:If you predict that the numbers will be that high, I think it might be worthwhile setting up a wiki page. It will make tracking names and quantities much easier.
Dave,
Check the Wiki here...
http://www.diyaudio.com/wiki/index.php?page=Toole+Regulator+PCB+GB+
Cheers
AndrewT said:
When do we get a proto done to prove the 4 layouts are correct?
As soon as we are ready for that, it will be done. The last details are being finetuned right now, and this may include a nice little surprise for you guys
Both the NS10 and the reg circuit has been built and confirmed to perform as expected. Check out the NS10 thread for that. The compact reg version will be tested again, because of the very different board-layout.
AndrewT said:
Get a quote for 500+ now, no point in waiting.
I'm getting the new board dimensions from Manu
and will contact the fab for an estimate.
Shipping cost
I've been looking at shipping options and Canada Post
Small Packet is probably the most reasonable choice.
The current rates are as follows:
USA:
||----------- || Surface|| Air ||
|| 0 - 250g || $5.05 || $6.56 ||
|| 251 - 500g || $7.20 || $8.55 ||
|| 501 - 1 kg || $10.70|| $13.25 ||
International:
||------------|| Surface || Air ||
|| 0 - 250g || $6.00 || $8.20 ||
|| 251 - 500g || $8.10 || $15.80 ||
|| 501g - 1kg || $13.65 || $31.0 ||
|| 1 kg - 2 kg|| $20.00 || $48.40 ||
The international rate varies slightly depending
on location. I've quoted the maximum rate here.
I'm guessing each PCB will be about 50g. Hopefully
this will give you an idea of shopping cost.
Dennis
USA:
International:
Dennis
Well, let me get this out of my chest, and tell you about the surprise that Steen mentioned earlier.
The Raw Supply is fine as is but some members (specially Steen ) suggested adding the possibility to use a prereg after the first cap and choke (L) for the sole purpose of adjusting easily the raw voltage to the Shuntreg and not that the Toolereg needs a prereg, just to make sure we all understand this.
The prereg is in the usual LM317/337 sort of thing so nothing fancy here and we still maintain the ability to bypass these components using a Jumper on the input/output leads at the LM pads; so nothing has been lost here.
Master tester Steen has already done these mods on his preamps and reports that is much easier to dial in the raw voltage there using a trimpot to the adjust terminal of the LM’s and has no detrimental issues to the Toolereg performance.
As you can see this greatly simplifies the application of our Tooleregs and avoids the need to search and maybe buy new trafos for each application or reuse… a single trafo could also support various raw supplies + Toolereg combinations at different voltages.
As usual, Manu is working hard finishing this mods to the Gerber’s which should be finished any time now.
Cheers
Cheers
apassgear said:Dennis,
Please remind the suppliers that these are 4 scored PCB’s
Cheers
Yes. Did that when I sent him the updated size info.
Thanks,
Dennis
Quick&drekky Protos have been sent to DK for testing and savouring purpose ...
Results in few days ...
Manu
Hi All
Thanks to all for organising this group buy. As it is spread over 2 or more posts ,I think it would be good for all participating in this GB for the PCB layouts, final tested schematics and parts lists for both the NS10 amp and regulators to be posted all together for the benefit of all concerned.
We look forward to further developments as you test the boards etc..
Cheers
Gary..
Cheers
Gary..
- Group Buys
- Universal shuntregulator, "Toolereg" NS-10 PCB-GB.
