As a said i am a dumb with I/V converters for DACs. I just wanted to know if the offset screws up the PCM1794A. In another thread we talked about canceling the offset from this DAC and then i had the idea if your UNIO can be set up to cancel that offset because it has an offset already. Your circuit is balanced and AC coupled and it plays already fine so there seems to be no problem.
Hi Rosendorfer.
It´s funny that you ask that. I have see it an hour ago in the post #15 of the thread
http://www.diyaudio.com/forums/analog-line-level/216557-xcen-balanced-single-ended-converter-2.html
It was you that design it ?
1.86 Vrms is strange. you should have 1 Vrms, with 1 Vrms the distortion should be lower.
I'm getting 51dB of gain. Flat from 10Hz to 100kHz. I didn't put your filter capacitors in yet.
To lower gain to say 16dB what is best to do ? I would like to try the Fet version as preamp. Is that 30dB single ended gain of each side or bal. gain ?
Without loop feedback, gain is controlled by the local feedback degeneration resistors.
- Digital Source
- UNIO a minimalist I/V converter
