Ultrasimple MM/MC RIAA preamp 2
pcb handmade for cascade version of Le Pacific RIAA, tests planned for this week
Last night I nailed down some NOS Vishay/Siliconix PN4391s and some National PN4091s. Layout is in the last stages of tweaking and checking. I may go out for boards this weekend. I'm also considering getting some Linear Systems PN4391s, as they use a different process with higher transconductance.
produced boards for cascoded version.. matching in progress of 2SK2394 's, Idss is from 12-17mA so Rs=20ohms is used for bias..it can be changed to any other value very fast because is in SMD 1206. PCB is accepting any other fet SMD or TO-92 package, so i can experiment with anything from the shelf
Here is one board, almost completely stuffed. I still need to select some JFETs and capacitors, and rustle up a few more SMB connectors for the ins and outs.
One board = one entire preamp, with 2 channels each of RIAA and line stage. The heat sink to the left is for the onboard discrete shunt regulator, that will supply +30V for the main supply.
Reactions: 1 user
The too many projects syndrome is one of my biggest weaknesses. I can relate.
I'm looking for a decent riaa solution. I don't want to spend ridiculous money on what should be a fairly "simple" circuit. (Yeah, right !?) Not easy but can be done. There's usually no way around a good MC setup trans to keep noise down. An extra 20 dB of gain in front can really mess things up noise wise. Plus, the trans will protect the cart from any DC offset, like some direct coupled fet stuff can have. The fewer caps in the circuit, the better for me.
