An obvious way to simplify the design is if you were to remove the bootstraps in the output stage. That will save 7 components. But then that would cost some efficiency, as the dropout voltage will rise 4 V. You can also remove the first amplifier stage, saving 4 components, but that will cause some DC problems, related to impedance of the driving stage.
I think the modulation of T15 is only of very low significance. Neither T9 or T5 are sensitive to change in their collector current through R24, the delta voltage changes only by a value determined by the Re (around 25 Ohms). So any modulation from E of T9 (in the region 0,5V) will be dampened 4000 times before it is sent back in the input stage in common mode. Here it results in a microscopic amount of Negative Feedback. I think no problem.
True but not much if you add PS.Nelson Pass said:
Hi lars. Nice .. really nice ...
Still if i would you i would leave the input cap in the circuit. without it and a low inpedance load you will get a serious output DC offset shift, when connecting the source, with such a high resistance seen by the -IN on the diff. input. i get like 400 - 500mV maybe more with my calculation when running from a +/35V supply.
With the input cap, i see no problem.
Lars,
Looking good, and very generous of you!
Of course there are things I'd do differently - but hell, we're all different - and there are several ideas in this which I believe are very good.
Have you built it, and how does it sound?
I guess that's what matters.........
Hugh
Hugh
Not all of it yet .. but the essential parts i have built (as a birds nest), when i can get a set of PCB's produced, i will post what the sound is like.
If anybody else beats me to it, please also post.
AKSA: Any new suggestions are of course welcome. I am sure you can make some good contributions. And since this will be an open source project, everybody in here can benefit.
Anybody would like the original schematic in Corel Draw, i can post it in a ZIP file. It's easier to modify than start over
AKSA said:Lars,
Hugh
Yes there are some refreshing idears in it. And i like the ULCA2 more than the ULCA1, it will have a more even slewrate in each directions.
i would think a low cost amp might want unusually good psrr since regulated supplies would be out of the question
in this example you have inferior psrr, particularly with the resistive bias of R18,28 for T12,13;
a quick est of T12,13 psrr at the output can be had from 26 mV/ 35 Vsupply *1% tol(R28,18) * 50 Av ~= 1/2800 or only 70 dB
while you might argue R28&18 will likely match better than 1% I would suggest you consider the delta R spec for exposure to soldering temp and the variation due to hand assembly (I regularly and severely overcook parts when reworking smt boards)
Hi
Yes this would definitely work, and the collectors should go to V- directly (not to the C of T10 and T11) so the base current would not go into the signal chain.
It is a bit hard to see the cost / benefit comparation of these two solutions. Both would work fine.
A completely symmetrical voltage amp is also a possibility, but it will cost another 4 transistors.
Hi Lars, what about the suggested improvement in PSRR resulting from eliminating R28/18 do you think this is significant? Also, would there be any benefit in replacing T5/7 with a current-mirror? I realise that these are essentially different ways of doing the same thing so there might not be a definitive answer.
Interesting amp though and miniaturised too. Finding matched pairs of those tiny transistors could be fun
So i'm not so familiar with use of depletion mode FET's as current sources. It seems to me that there is typically a very large Vgs off tolerance on these devices, so how do you determine the value of the current source without adjustment?
And how about high temperature leakage of the FET, from datasheets it shows that the leakage goes from 10uA to 1 mA at 125 deg. C. Is that really the case?
If use of these 'Current Diodes' can improve the design, then why not?
- Ultra Low Cost Amp Design
