UCD 25 watts to 1200 watts using 2 mosfets
to GOD be all the glory. my latest project based on this forum. i read notes on ir class d layout and there has been an improvement on noise issues . this is more silent than my previous designs .
works well but care has to be taken when soldering smd parts . some are too close to each other, maybe some day i will order a pre soldered board :cool: :cheers: have fun all
  • gtG ucd 1100 rev 1.0 with protect semi smd part list.pdf
  • gtG ucd 1100 rev 1.0 with protect semi smd pcb bottom.pdf
  • gtG ucd 1100 rev 1.0 with protect semi smd pcb top.pdf
  • gtG ucd 1100 rev 1.0 with protect semi smd components 2.pdf
  • gtG ucd 1100 rev 1.0 with protect semi smd schematic.pdf
You design a version in tht ? Or equivalent smd transistors ?
What needs to change for transistors irfp250n ?
hi all my ucd class d . i powered mids at +/-75vlts and subs at +/-85vlts outputs irfb4227 . i used two half bridge smps gdt, irfp 460
  • gtG ucd 1100 rev 3.1 with protect components smd confirm .pdf
  • gtG ucd 1100 rev 3.1 with protect schema.pdf
  • gtG ucd 1100 rev 3.1 with protect pcb v2.pdf
  • gtG ucd 1100 rev 3.1 with protect components full .pdf
