to GOD be all the glory. my latest project based on this forum. i read notes on ir class d layout and there has been an improvement on noise issues . this is more silent than my previous designs .
works well but care has to be taken when soldering smd parts . some are too close to each other, maybe some day i will order a pre soldered board have fun all
gtG ucd 1100 rev 1.0 with protect semi smd part list.pdf44.2 KB · Views: 421
gtG ucd 1100 rev 1.0 with protect semi smd pcb bottom.pdf37.9 KB · Views: 445
gtG ucd 1100 rev 1.0 with protect semi smd components 2.pdf234.8 KB · Views: 577
gtG ucd 1100 rev 1.0 with protect semi smd schematic.pdf45.8 KB · Views: 863
I would like to ask I have IRFP250n from Harris semicondutor.. what the value of gate resistor I'm going to use.. I will use it in my IRS900
Use 33R Or 39R resistor (fsw=300~350KHz)
Use 47R for 200~250KHz fsw
MANOJ
IR9OO
Sory.i understand what the componen bias on pcb?
Please contact with me
Hi Mr.Thien
I am Minh, i want to contact with you as my email:
minh.np2007@gmail.com.
Please send me email if possible. Thanks you so much
Minh.
And PDF file ....
regards
Hi Mr.Thien
Minh.
You design a version in tht ? Or equivalent smd transistors ?
What needs to change for transistors irfp250n ?
Hi all
my new AUD600 Rev. 1.2 with limiter using NJM2761. Very simple circuit.
regards
manoj
could you please share yourown circuit for the NJM2761,THS!
22uh
Sent from my HTC Desire 516 dual sim using Tapatalk
hi all my ucd class d . i powered mids at +/-75vlts and subs at +/-85vlts outputs irfb4227 . i used two half bridge smps gdt, irfp 460
gtG ucd 1100 rev 3.1 with protect components smd confirm .pdf48.4 KB · Views: 521
thank you for sharing
it is so good
can you redrawe in one layer pcb?
used the sub channel @ 2ohms( four 8ohms 18" subs) and it warmed after pushing it hard for two hours. the mid channel I used 4ohms .and all was well .
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
