Hi
greetings ugly wiring but its WORKING many many THANKS to CPS DIMONIS
and NORAZMI for their valuable help
warm regards
andrew lebon
Hello,
Have you tried cakeamp too?
hi guys is this fet good with this amp irfb4229 at +/- 90vlts at 2ohms ?
stewin,
23n20 has the breakdown voltage of 200V , they aren't good for +\-90V application .
So as the other 200V mosfets !
4229 has 250V breakdown .
thanks dimonis, now i've got a reliable D mosfet(irfb4229) to use i hope it wont heat up like crazy as the irfb23n20
Hi Stewin, can you post it to here? thank you!
I think this thread is devoted to amps based on LM311+IR2110 , and not to discreet . Sorry thwcs.
Hi Manojtm i used 600 khz oscillator based on your schematic my IR2110 IS DEAD,my IRF240 also dead,hope you can post your schematic with modification,thank's.
Wowww... 600Khz? Manojtm used 125 Khz.... Using NE555 square oscilator and converted do triangle.
Hi All
tested my design its AMAZING POWER!!!!!!!!!
no noise Clear sound and good power
when i check speaker line without signal it showing -16mV this problem i want to clear ....
which schematic are you using?
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
