UCD 25 watts to 1200 watts using 2 mosfets
I get quite low distortions in these demo test version in spice.
hi manoj
plz.help me to built this amplifier as i have assembeled but not working.thanks
need more details , before treatment
(because this is complex circuit system with 6 different circuits + protection logic)
give you some tips
1.do not apply more than 90V-0-90V (problem of 2n5401 and cd4049)
2.limit the switching frequncy to 120khz(BD139 and BD150 slow)
4.change 100ohms (mosfet bias resistor) to 27ohms (dead time too long)
5.chand that 10W idiot resistors use only 2W 5.6K (90*90/8.2k=0.98W)
6.add 10uf(low ESR) to IR2110 bootstrap (to bias 3 mosfets + 3 100ohms +gate drivers)
.....use 2 pair of mosfets and remove gate transistors connect directly Ir2110 driver drive 2+2 irf4227 easyly ... set switching frquncy 180khz
output inductor 40uh
give you some tips
thanks dear
i will try .thanks
