Twisted X Overture
Cap values
Hi Russ
I,m putting together a TXO with the layout files you kindly provided in the beginning on this thread.
However i can not seem to find what values the Caps in the Schematic is.
Is it specified somewhere and i just missed it or is there an reason for this not being shown?
Maybe a BOM is around that i could have ? :)
Looking forward to listen to it.
Z
Re: Cap values
Z
You are right! I forgot to post the full BOM, here it is. :)
You will notice some of the values are different from the original schematic, that is because I have found the values I am posting here to be better after nearly 5 months of testing. :D
The big electrolytic caps can be any good low ESR cap from 220uf on up to say 1,000uf(if they fit).
I have used 220uf panasonic FMs and FCs as well as 470uf rubycon YXF.
I really hope you enjoy your project. Please keep us posted.
Cheers!
Russ
  • txo_parts.txt
low sound and distorsion
Hi Russ (and others ;) )
I finaly finished a home etched TwistedX. Hooked up one channel with laptop as source and crappy speakers..
No smoke.. :D
However.. sound i get is veeeery low (can just hear music) and the music is very distorted..
I,m lost. I have checked values and all seem to be correct,.
What could cause this to be?
I have no clue on where to start the hunt for the problem..
Can anyone help?
/Z
:xeye:
Hi Russ.
The component values is the same as in the BOM you posted in this thread a few posts up :)
And the layout is the singlesided version you kindly provided in the beginning.
I,m using a 2X24V 300VA toroid with 20000uF..
Mmm what else,, that,s it i think..
I,m concerned about if i should connect the minus to ground when not using a balanced signal.. Can anyone confirm this?
Thanx
/Z
