I bought the PCB from a local shop.
Using Russian 6N23 tubes (same in my MF Tubalog). Using Wima's & Rubycon in signal path. EPCOS, Rubycon, United Chemicon for the other parts. The A42, A92 and all resistors are generic and was purchased from the same shop. Using IN4004 (extra's from my upgrading my two pairs of Quad 33/303) in-place of IN4007. LED is green as per suggested by other forums to be less noisy than the rest.
When I tried with another wall PSU - 13V and 800mA in-place of the 12V 500mA PSU, sounded brilliant for a few seconds before it returned to the "breaky" output.
I am suspecting a voltage/mA issue rather than parts. When I searched other forums, someone did mention they could not a make MF based tube buffer kit sound nice with 12V and had to use 2x - but no mention of the actual kit or PCB variation used.
Thanks!
Thanks!
Yes, but the original design was awful! Getting the voltage up is a good idea (assuming the "designer" of the piece used caps with reasonable voltage ratings).
The stuff about green LEDs being less noisy is questionable. In that position, the LED has zero to do with noise, and the noise of any LED is ridiculously low.
did u get the pcb from koba/Another update. Went back to the local shop and obtained a unregulated 12V 500mA off-the-wall PSU. Works fine.
Lesson for me. Unregulated off the wall PSU is with a wave-ly line on the power source output. Regulated output has a bar with 3-dots over it.
how much did u get the whole MF tube buffer kit for? able to pm?Yes.
Good service. Very helpful.
I have details of the unit in my blog at MyOldVintageHifi: DIY - Tube Buffer
It is now in 4th iteration (no pix). Basically the 2 caps on RHS of the board only shows 15.xxV on a multi-meter. These two 1000uF 35V were replaced with two 2200uF 25V. Found the background levels to be lower after doing so.
Instead ecc88 if I ask what 12ax7 (ecc83) should therefore modified in the sematics?
(schematics LS29-Musical Fidelity x10-d)
Thanks for your help!
The 12AX7 has 12,6v heater voltage and higher amplification factor.
12AX7 can be run on 6.3V heater too, but is so unlike the ECC88 that it is a daft question to ask if a design can be modified to switch between them. It would be a new design.
Yes but you must modify the pcb connecting 6.3v to pin 9 and 4-5(shorted)
Ghost22
Do You actually own any of the tubes you wish to substitute or is it as I suspect a hypothetical question?
Quite frankly anybody with half a brain could deduce from the data sheets any changes, physical or electrical that would be needed.
The Valve Wizard -Cathode Follower
the 6J1 buffer is a crap design, originally designed using a 7pin EF95/6sh1 Pentode, Triode strapped. the 6DJ8 and 6n23 are 9pin Dual Triodes.
The other Yaquin design - CD3 uses Dual 6SN7 in parallel, both it and CD1 at an insanely non-linear operating point.
John
Both designs basically put 150v on the Anode and 80v across the tube at 1mA.
As buffers, these sort of currents will be unable to drive the capacitance of a chocolate fireguard let alone a long Interconnect (Slew Rate).
John
The song may remain the same but the quality suffers
That reminds me of this as to the quality of it ability to drive The chocolate fireguard experience Paranoid performed by The Chocolate Fireguard Experience at The Kings Arms in Colchester - YouTubeGhost22
John
- Tubes / Valves
- Tube Buffer 6J1 / 5654 (6AK5)
