For a center or surrounds you might want the same "voice", so I'd use the Duet drivers and crossover in small sealed boxes, just keep box Q below 1 for the center(if you want prominent male voices) and below .8 for the surrounds. That way you will match the tone of your mains, as TLs sound like low Q in upper bass and low mids. You can tweak the xover a little if you have boundary issues. Not an issue most of the time if your HT receiver can or does designate them as 'small'.
All TLs don't sound the same just as all ported boxes don't have boomy bass. It all depends on the driver, the TL design and the designer.
Paul
Paul
as TLs sound like low Q in upper bass and low mids. .
The duet drivers would be too big I would think
Wouldn't the voice sound be more important in the center than the satellite I have always been told that when the receiver is set to 3.0 or up it try's to prioritize the voice to the center channel so usually the center have more voice and the sats on my receiver I know only are for ambient noises and I have only heard voice out of them on music and one episode of family guy
My 2-way RS duets paired the RS225-8 in an ML-TL with an RS28F crossed at 1400 Hz with a Cauer-Eliptical filter.
Where can I find the details of the enclosure? (I'm going to google it now...)
FOUND, thx
- Transmission line design
