its possible to heat the copper hot enough to anneal it (400+C)
and the insulation will still survive.
How To Anneal Copper
The copper should be clean and bright, otherwise oxides will form and become embedded in the surface on heat-up, and should be warmed up with a blow-lamp (a kitchen stove will do this at a push) generally rather than at a specific point, although copper tends to spread heat quickly through the metal.
Once a background heat is produced, when the metal shows different colours radiating away from the heat source, then you are looking for a dark red (plum colour) reaching the part you want annealing – it’s like the colours of the rainbow moving from blue through to bright red as the hottest.
Once this occurs quickly immerse the copper you are annealing into a water bath, and that’s it. Job done.
The easy test is to tap it with a screwdriver or something similar. If you hear a ringing sound, the copper is still hard and needs to be annealed again. If the sound is dull then you have annealed the copper properly.
Don’t delay the quenching too much otherwise you will not achieve the annealed copper you were aiming for.
Before you begin to work the copper you must remove any surface oxides that have formed with a wire brush, wire wool or emery cloth as these become embedded, spoiling the appearance, and are difficult to remove later.
Annealing the copper requires a high temperature. Copper melts at 1357Kelvin
and annealing generally occurs at greater than half the melting point in degrees K; even
higher temperature causes faster annealing (but not past the melting temperature, of
course). Typical temperature to use is 400C or 700F.
Annealing
Softening or annealing of cold worked metal is accomplished by heating to a temperature that causes recrystallization and, if maximum softening is desired, by heating well above the recrystallization temperature to cause grain growth. Method of heating, furnace design, furnace atmosphere, and shape of work piece are important, because they affect uniformity of results, finish, and cost of annealing.
For copper and brass mill alloys, grain size is the standard means of evaluating a recrystallizing anneal. Because many interreacting variables influence the annealing process, it is difficult to predict a specific combination of time and temperature that will always produce a given grain size in a given metal.
Several copper alloys have been developed in which the grain size is stabilized by the presence of a finely distributed second phase. Examples include copper-iron alloys such as C19200, C19400 and C19500, and aluminum-containing brasses and bronzes such as C61500, C63800, C68800 and C69000. These alloys will maintain an extremely fine grain size at temperatures well beyond their recrystallization temperature, up to the temperature where the second phase finally dissolves or coarsens, which allows grain growth to proceed.
Generally, two annealed tempers are available: light anneal, which is performed at a temperature slightly above the recrystallization temperature, and soft anneal, which is performed several hundred degrees higher, at a temperature just below the point at which rapid grain growth begins.
When annealing copper that contains oxygen, the hydrogen in the atmosphere must be kept to a minimum to avoid embrittlement. For temperatures lower than about 480oC, hydrogen preferably should not exceed 1%.
sure, but only for a few seconds.
the copper from that coil was about as soft as lead.. i don't believe 300C is enough to anneal copper, but i might be wrong.
the operating temperature (continuous) rating of magnet wire is based on service life IE break down of the insulation system.
the most common polyester wire is rated around 130*C
the highest class is Polyimide insulated magnet wire is capable of operation at up to 250°C
one shorted turn is usually enough to finish off a transformer
- Power Supplies
- Transformer operation
