Hello everyone, new to the forum
very helpful thread indeed, thank you all
I thinking of building an amp to power two outdoor passive speakers Klipsch AW-6500 (8 Ohms 85W, 95db) or Bose env 251 almost same rating although Bose states that they 6Ohms and 100-200W recommended amp.
In the future I'll be adding a DIY passive sub to the setup, so I will need a a three channel output which I think is being referred to as 2.1 configuration, correct?
from what've read so far the TPA3255 is recommended for 8Ohms application, or is it too powerful for those speakers? Shall I be looking at the TPA3251 instead?
I also want include a bluetooth 5.0 CSR8675 in the build, does any one have a recommended module that I integrate in the amp? Will this require a separate power source ie 12 vs 48 volts?
