Thanks mate. I wonder how the 3 middle Bulk-Cs have any significant impact on performance due to their loop-size. Beside this, is this a 2oz board?
this is a 1oz board.
but for the 3 middle Bulk-Cs.
do you mean the 5 bulk-Cs on 36V to GND?
they have slight impact on THD+N in higher power output range,also will significant impact the peak power.
Oww at last, been waiting for a tpa32* board for ages!
Are these from a small production run? If so i guess that explains the price? or are these boards just always going to be £76 always, even in high volume production? I prepared to pay that amount if thats what its going to be anyway for extra good quality, long lasting amp board but if there going to be runs that are same quality but cheaper that would be great
Note: that I would prefer to buy products that had less environment degradation in there production and am prepared to pay the extra cost for that, if needed, providing theres proof.
Thanks muchly!
Thanks muchly!
What is the reason for the peak in THD around 6kHz?
You'll find more in depth info in the main TPA3251 thread...
There are a few, do you have a link? Thanks!You'll find more in depth info in the main TPA3251 thread...
Why do you use a dual OPAMP (JRC 4580) instead of an INA134, THAT 1200 or a SSM2141 please ?
Why not?
Those JRC4580 are pretty good and totally underrated.
Yes, but my question was more about the technical utility of a balanced line receiver instead of an op amp for a balanced line input buffer.
Hi all, I'd like to use these TPA3251 for my active speakers.
Ideally one board per speaker enclosure, what will happen if I put a med on A input and the woofer on B input ? (I will have else mono boards on tweeters)
A forums friend (which has design his own TPA) says the BTL configuration won't be OK, needs to put the 3 and 4 pins to the VCC instead of the GND, can someone confirm ?
the on board AFE is an optional design for supporting single-ended or differential input,that make sense for Diyer with various input source.
sure,you can totally remove this and feed your diff source to the chip input directly,that will get the best performance.
btw,make sure the analog input source is low noise,low impedance.....
Hi,this board only support BTL mode(2 channel ),
i guess you want 2.2 channel with SE mode.
- Class D
- TPA3251 2Ch Amplifier Board DIY Design (Compact size/Amazing Performance)
