adamus said:item recieved thanks.
all test within 6.2 and 10ma idss.
Do you mean this parts has Idss vary between 6.2 and 10ma..?
Did you test it by just applying like 10V supply across D - S (with gate and source shorted)?
Hi Spencer,
I just received the parts today, it is a fast shipment thanks!!
Apologize my ignorance and lack of knowledge but could you help me to confirm if the parts I received coming from the same batch as posted in this thread? As compare to the beginning post#5 the part is different....please find attached picture of the part I received.
I don't know if others reveiced the same parts as mine?
Thank you,
Joshua
Thank you,
Joshua
I am selling the PART 2SK170BL from Toshiba and will not ensure anyone get the same date code as in the previous post. Your part date code is 8G which is a 2008 production batch. This is less than a year and you get all NEW and recently made part.
But I can ensure that each part I sold out in 100 pcs are from the same date code (batch).
Please note that this is a normal pratice even if you buy anything from Digikey, Farnell or even directly from the manufacturer.
The parts are good and can be used without any issue.
Spencer
Spencer
spencer said:Hi,
Spencer
Hi Spencer,
Thanks for your prompt confirmation and explanation. That's all I need to know...
Joshua
