Pavel -
Of course no one here would understand because of the language barrier.
SY, I would appreciate if you could sweep the rubbish.
Pavel
I have read his site, google translate is sometimes ok.
I agree that its a lot of rubbish, but otoh this is an open forum, and I have seen a lot of other threads with more rubbish.
SY you are in a hurry?
Cheers
Pavel
Cheers
When you're my age, you don't even buy green bananas.
I always look at the amplifier's own eyes. I described the causes Transistor sound here.
Federmann Bohumil. Tranzistorový zvuk počítačové simulace příčin jeho vzniku. Perspektivy elektroniky v roce 2009: 26. 3. 2009. Rožnov pod Radhoštěm: SŠIEŘ RPR, 2009, s. 19-25. ISBN 978-80-254-4052-0.
Please add your experiences.
Is not a supporter of THD measurement range, in my opinion is not sufficiently informative about the properties of amplifiers. I we will wait until everything is ready and will be measuring and listening tests.
I am also very curious to understand how your novel output stage works. It uses only N-channel MOSFETs in both push-pull halves :
Technical parameters of amplifiers 4Ω
End transistors 2 x 4 x IRFP240/9240
Technical parameters of amplifiers 2Ω
Technical parameters of amplifiers 8Ω
PMA
PMALibrary, Library Eagle
Guys,
If you have any personal or commercial feud, you should take it in private. This thread has absolutely nothing to do with DIY. Even the pictures (or schematics, or whatever they were) are no longer available.
They are, to me.
They are, to me.
I can't see the pictures and don't have access to the web site.
Very easy to create your own library device (symbol, package, device). It might be confusing if you as a high school teacher at technical college use N-MOSFETs instead of P-MOSFETs, at least for your students.
- Topology Federmann, HQQF-55 ...
