Load both windings to deliver 2.4Aac + 2.4Aac into 9r17 + 9r17 and check how hot it gets after 30minutes.
22Vac+22Vac @ 2.4Aac+2.4Aac is equivalent to an output rating of 105.6VA
Thanks Andrew. How many watts would I need for those resistors?
Each will be taking ~53W so they will get very hot. Try 100W with good ventilation.Thanks Andrew. How many watts would I need for those resistors?
Tony's Line conditioner finished.....230V primary to 230 volt secondary
rated for 1500VA, has a low power winding good for about 200 watts
to use on low power such as test equipment....
new traffo for a second 6C33 OTL amp build......
1 3/4 inch center leg, stacked to 4 inches, and weighs in at 12kgs..
winding electrostatic shields...
sun drying after soaking in electrical varnish...
finished traffo...
finished traffo...
to all masters
i want to build a traffo for my APEX500 since i cannot find traffo in our area that has correct va rating, since commercial traffo indicates false VA (in our area).
first Q - will 55-0-55 be enough for b500? how many amperes?
all i have found in the market was EI core with CL 1 1/2" and CL-3"
i bought about 1.5"x5" inches coz 3"CL has the height of 6.75"more or less and the price is 300% higher.
may i ask the specs for the primary and secondary windings?
vis-a-vis t/v and primary and secondary turns.
thank
regards...
thank
regards...
1.5"x5" inches will give you about 1500 volt amperes
so that 2 x 55 windings will give you 8 amperes....
still good for your intended project....
this as far as i go....
you have to study on your own about the winding details,
enough information are available on the net.....
Thanks sir Tony,
regards
This is so cool! I wish I'd have access to all the materials. Then I'd surely get a winding machine for myself. Making transformers is such a fascinating task. I did a few some decades ago, using a very simple winding jig and after having bought the wires, laminations etc. from companies in my neighbourhood that no longer exist.
Best regards!
Best regards!
Best regards!
thanks, winding traffos is a therapy of sorts for me, helps me relax, and lots of
good ideas comes to mind.......
thomas skinner transformer laminates.....https://www.thomas-skinner.com/transformerlaminations.htm
Tempel
Tempel
Hi Tony,
Is there a place where I can purchase reasonable quantities of EI laminations? At this point I dont really care about geographic location, I just need a source that doesnt consist of a shipping pallet .... lol
try edcorusa.com
Hello, this is my first diy transformer I will still immerse in the varnish, thank you Mr. AJT inspires us with your monatges! Congratulations.
Core: 45X45mmX type GNO 0,5mm
Power: ~ 328VA in the secondary
Primary: 110 / 220AWG19
Secondary: 28AC / 5A AWG16 + 28AC / 5A AWG16 and 12AC / 1A AWG22
Current density: 4A / mm2
* Bmax: 10000gauss
Efficiency ~: 80%
Sorry for my rude English
* Bmax: 10000gauss
Efficiency ~: 80%
new isolation traffo build,rated for 1000 volt amperes, 240 volt primary to 240 volt secondary...
- Power Supplies
- Tony's latest traffo DIY build
