Tony's latest traffo DIY build
Tony's Line conditioner finished.....230V primary to 230 volt secondary
rated for 1500VA, has a low power winding good for about 200 watts
to use on low power such as test equipment....
new traffo for a second 6C33 OTL amp build......
1 3/4 inch center leg, stacked to 4 inches, and weighs in at 12kgs..
winding electrostatic shields...
sun drying after soaking in electrical varnish...
finished traffo...
to all masters
i want to build a traffo for my APEX500 since i cannot find traffo in our area that has correct va rating, since commercial traffo indicates false VA (in our area).
first Q - will 55-0-55 be enough for b500? how many amperes?
all i have found in the market was EI core with CL 1 1/2" and CL-3"
i bought about 1.5"x5" inches coz 3"CL has the height of 6.75"more or less and the price is 300% higher.
may i ask the specs for the primary and secondary windings?
vis-a-vis t/v and primary and secondary turns.
thank
regards...
This is so cool! I wish I'd have access to all the materials. Then I'd surely get a winding machine for myself. Making transformers is such a fascinating task. I did a few some decades ago, using a very simple winding jig and after having bought the wires, laminations etc. from companies in my neighbourhood that no longer exist.
Best regards!
Best regards!
thanks, winding traffos is a therapy of sorts for me, helps me relax, and lots of
good ideas comes to mind.......:cool:
Hello, this is my first diy transformer I will still immerse in the varnish, thank you Mr. AJT inspires us with your monatges! Congratulations.
Core: 45X45mmX type GNO 0,5mm
Power: ~ 328VA in the secondary
Primary: 110 / 220AWG19
Secondary: 28AC / 5A AWG16 + 28AC / 5A AWG16 and 12AC / 1A AWG22
Current density: 4A / mm2
* Bmax: 10000gauss
Efficiency ~: 80%
Sorry for my rude English
new isolation traffo build,rated for 1000 volt amperes, 240 volt primary to 240 volt secondary...
