Re: volume control on NS10
yes-just a pot on input
value-whatever you choose from 20 to 50 (even 100) K
Dennis Hui said:Hi,
What an interesting thread!
How is the volume control hooked up on the NS10?
Is it just a pot at the input? If so, what is a good
value? (I vaguely remember reading about 20K ohms,
but can't seem to find the reference.)
Thanks,
Dennis
Re: Re: volume control on NS10
I would use a 10 or 20K (depending of source impedance) this way avoiding high impedance nodes.
Yes, pcb's are from those shown on this thread. Hope to find some time to get started with those toys and report my findings.
value-whatever you choose from 20 to 50 (even 100) K [/B]
Thanks for the pointer, Apass Thats pretty much the roadmap we set out At this point I have a Threshold A400 on hand But (there is always a but arent there?) the guy will only part with it if I take the preamp too The preamp is a Music Reference RM5. Not too bad I guess? Any Oppinions? To be honest, I really dont need another preamp. But I guess I could just sell it on Ebay or something. Should be in nice working conditionCheck this awnser from Nelson an the Threshold FET Thread.
Steen
What do you think of the RM5? I know it was a pretty nice darling of the reviewers at some point I also know that it was produced for over 20 years I couldnt find any on Ebay (no finished items either) So where does that lead you??
Steen
Edit: Just found that you can still have it from new 1995usd.
Steen
Steen,
For many years I used a similar line preamp, a diy single tube 6922 grounded cathode, which the RM5 is. Soundwise is very nice with the right amount of warmth, somewhat rounded bass – fitted with a good tube, that is. I should add though that my version was very well implemented at the PSU, lots of MKP’s and a couple of small coils at each B+ and running at high bias. The last mods I did used batteries at the cathode for biasing.
The spec for the RM5 says it has 800 ohms output impedance, which I very much doubt, the best you can get is about 1.2/1.5 k if memory serves.
I cannot comment on the RIAA amp though.
You lucky guy, let us know how the the A400 sounds with the NS10 and your other nice preamps.
Naah, I dont know Moddy. I just told the guy that he could keep his RM. I am only interested in the Threshold (So far ) Lets see what happenslucky bstrd!
Steen
steenoe said:PSU board to the left is 9,5x7 cm. (2 supply's) Linestage board is
9x5,5 cm ( 1 channel) Measurements are approximate.
Steen
Steen
What trafo values (VA, secondaries V) are you using for your NS10 clone psu. I may have missed something in all these many posts. I´m trying start to collect parts for implement this preamp.
In advance thanks for comments and assistance
JC
steenoe said:Naah, I dont know Moddy. I just told the guy that he could keep his RM. I am only interested in the Threshold (So far ) Lets see what happens
Steen
didn't saw this post.....
anyway-I wish you luck with this crappy old amp
First of all, I didnt build the version in this thread yet. I did build the version in Russ's thread with the dual supply, in fact it is still doing great service in my working room Whatever we made in that thread (surely not a NS10) it sounds really good indeedWhat trafo values (VA, secondaries V) are you using for your NS10 clone psu.
My guess is that a 50 VA, 22 volt trafo would be nice for the real clone. But I suggest that if you have something on hand you could try and use that. A 2x12V donut would propably do nicely, running the secondaries in series, or a 2x20-24V running them in parallel or one for each channel. Watch the heatsink on the regulator, if you are using a 24+ volt trafo though!
Thanks a lot, Modanyway-I wish you luck with this crappy old amp
Steen
I have a question, and I am not sure this is the right place to ask it. Nonetheless since you guys are pretty reliable here goes:
Working on my NS10 (real thing ) I found that the supply consists of one (1) FT317! pretty surprising, but I am not the one to critisize anything, since it works pretty good!! The single FT317 feeds both channels. Here is my question (just in case you were in doubt ) Would it be an advantage to put in a new LM317 instead?? I have no idea if the 317 family improved over the years??
Steen
Steen
steenoe said:I have a question, and I am not sure this is the right place to ask it. Nonetheless since you guys are pretty reliable here goes:
Steen
If you don't want major tweaks (and you sez that you don't) leave it as is......even if you change it,you will not hear or measure anything.
just replace what you already planned
Thanks a lot Mod'y. I will do just that You know, its not even that easy to make the NS10 shine as new!! Man it cost's and takes more work than I would have thought!! But, I am determined to make it shine again It will, I am surejust replace what you already planned
Steen
steenoe said:Thanks a lot Mod'y. I will do just that You know, its not even that easy to make the NS10 shine as new!! Man it cost's and takes more work than I would have thought!! But, I am determined to make it shine again It will, I am sure
Steen
why you just don't send that crappy preamp to me for proper disposal?
ya know-those old gadgets are not in fashion even more
Nahh, dont think so This is one special old gadget, that makes my drums beating.)ya know-those old gadgets are not in fashion even more
Steen
steenoe said:Nahh, dont think so This is one special old gadget, that makes my drums beating.)
Steen
ya know steen-it's realy time for some 15" based bastardz in your room.......and I don't mean on subs....I mean on coaxials or something.......if you can't afford VOT........
you hardly can have this sort of dynamics with 7 or 8"
- Threshold NS10 Lineamp PCB
