"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets
The 110 Vac version, better than two words explain, given that this SMPS has the certifications.
is not a simple modification, the 110Vac version uses the same filter EMI shielded, but held 6A, instead of 3A (at 230Vac).
resistors and capacitors changed to high voltage, power unit changed.
emi / rfi tested.
I mean, that runs at 110/125 in a "native" way. (do not use the bridge to duplicate the voltage) then the 110 version is permanent
in this way, can operate at max 45/55V with 12A output
Joined 2009
I made a mistake - fixed - I hope
BuildMeSomething 2x DPS-600-45/55V (Reg LME)
lolo 6+4 x DPS-600-45/55V (Reg LME)
Emphrygian 2x DPS-600-55/65V (Reg LME)
igor0203 2x DPS-600-55/65V (Reg LME)
QRikard 2x DPS-600-55/65V (Reg LME)
qusp 2x DPS-600-55/65V (Reg LME)
NicMac 2x DPS-600-45/55V (Reg LME) (or 55/65V if no more 45/55V are available)
Update
NicMac 2x DPS-600-55/65V (Reg LME)
Stop 45/55V
it wasnt the price, I was trying to save Roberto and AP work of all the individual shipping given the discount, but if hes happy with that, then go for it, I agree the 22eu is good, even 35 is pretty good compared to usual to AU.
does this green version mean any delay for production? I thought they were already built? thats how it was presented. I dont wish to change cosmetics if it means delay, delays can be extended by extenuating circumstances.
no delay for green color of power-unit, this is new idea of AP.
..not ask me reason, i think green...nature ahah! yes it is strange color (i like it) but...dps-600 is not normal.
well, for all products we use final test before shipments, then after payments, products start in 1-2 days. UPS deliver in 3 days and guarantee within 5 days max for some countries.
Today i have received confirm via PM from Qusp & NicMac.
regards
"Just my curiosity.. where are the tons of diy who bought the amp wire? all of these use the linear psu maybe? "
I am going for a Linear PSU , the only reason is I already have the PSU and chassis that originally housed a pair of SKA GB300D's
I received my kits today, the SMD parts look a lot smaller than in the photos!
Good Luck with your builds
Joined 2001
Update
Arthur 4x DPS-600-55/65V (Reg LME)
Stop 45/55V
Hi all,
Tomorrow I close the GB.
I inform you via PM about some good news about the vat. Certainly this condition will not be repeatable. AP is likely to put on the shop, the version for class AB (DPS-600) but will the outputs with regulators, for + /-15V standard, also power-unit color is green. Therefore, this version for Wire Amp,will be ordered separately. it is not possible to buy only 1-2, then, you must create another GB (if there are interested clients).
well, today we will have some tests in the lab, just to save time and send faster. Still someone missing from this list, please confirm your address via PM etc by tomorrow.
Best Regards
Hi
Update
availability 4xDPS-600-55/65V yes
45/55V- ended
payments: Lolo; QRikard; NicMac
Can I just confirm the price each for these please.
€136??
Is that + 20% VAT into the UK? And the £10 import fee?
+ €22 for shipping?
It'll be 2 x DPS-600-65/75V (Reg LME)
I estimate that at about £318 a pair delivered?
Is a heatsink needed for this? Are specific connectors needed? Can I solder power wires to the board?
Thanks.
€136??
Is that + VAT into the UK? And the £10 import fee?
+ €22 for shipping?
Thanks.
AP2 managed to get the final price down for us to 140 € including VAT (per SMPS). The shipping is 22 €.
There should be terminals to connect the wires and i think AP2 will show some pictures of that in the coming days. And he said that all screws and plugs are included in the price
has to be solder, the screw terminals suck the life right out of the sound :rolleyes: I must admit though, I will likely solder it too if possible for the terminals to be left for us to install. initially for testing i'll rig up something to clip leads to
bloody paypal and their double dipping, conversion to EU I got at 0.758, but its actually 0.785, plus they will take the fee from Roberto.
Thanks for your responses Q, l and q :)
I just had a look at the website for UK Customs Duty, Excise Duty and import VAT:
"For goods brought in or sent to the UK from the EU there's no extra VAT to pay."
No Import fee either. Excellent :)
so; €140 = £113 x 2 = £226 + £17.80 = £243.80 delivered.
Or I could perhaps just about get 2 x 600VA transformers and 2 x 80,000uF 80V for that. I already own about 80 x 10,000uF, new and unused, mostly 100V and 10 x 1kVA and about 10 smaller Trafos.
Update
45/55V- ended
payments: Lolo; QRikard; NicMac;Qusp;Paul(?) sorry, i need you nik name Paul
Please, see this photos for connectors.
http://www.diyaudio.com/forums/soli...ifier-based-lme49830-lateral-mosfets-120.html
Connectors are assembled, no problem from power dc but..it is possible replace it with 3 single gold PIN D=1,5mm and solder wire.
Package include all you need, screws incluse (inox steel)
